Trent Meteor for 2015 start.
24 Jan 2015 18:04 #121 by Ex-Member
Replied by Ex-Member on topic Trent Meteor for 2015 start.
Quote from the Mini-Caprice thread: "You have been a busy boy today Andy.
Be ready for covering tomorrow at the rate you are going. "
You're not doing too badly yourself, Tony!! :cheer: :cheer:
24 Jan 2015 18:30 #122 by Quorneng
Replied by Quorneng on topic Trent Meteor for 2015 start.
When sheeted with balsa do the aux fins actually need spars?
I would have thought a balsa/Depron/balsa fin was already a spar. :P
24 Jan 2015 19:11 #123 by Ex-Member
a bit of 6x6 balsa to help locate the two halves when i slide them together for final glue and fit, it also acts as a stiffener.
25 Jan 2015 16:37 #124 by Ex-Member
Elevators made, well nearly.
cut to shape, hinged and ribbed (for your pleasure :P )
next :P job is to work out where to fit the servos and control horns.
then final sand to shape and i can cover the lot with 3mm Depron.
got 30mm of travel each way at the mo, will this be enough ?.
25 Jan 2015 19:08 #125 by Ex-Member
Look's good Tony - as a matter of interest, what's the span of the tailplane?
25 Jan 2015 19:21 #126 by Ex-Member
900mm span Andy. :)
That's bigger than most of you models. :P
25 Jan 2015 21:05 #127 by Ex-Member
Tony B wrote: 900mm span Andy. :)
More than twice the size in most cases! :lol: :lol:
28 Jan 2015 20:48 #128 by Ex-Member
Tail plane is sheeted.
finlets are glued on.
i have started the brown paper covering on the tailplane now.
elevators have been sheeted as well. i need to sand them to shape yet and then i can add the false ribs to the outside and cover with tissue.
29 Jan 2015 00:09 #129 by Quorneng
It does seem a bit odd to create a stressed skin elevator and then add false ribs on the outside so it can be tissue covered to make it look like the fabric covered 'open' structure of the original. :P :P
29 Jan 2015 06:44 #130 by Ex-Member
yup i don't do normal. :P :P
i didn't feel it would be strong enough as an open structure at this size.
29 Jan 2015 17:38 #131 by Ex-Member
well today has been a slow day.
in have sanded the elevators to shape, though the tips need finishing off a touch.
then i added the false ribs to the skin, i will sand them down when dry and then i can cover them.
Also i finished covering the tailplane, needs another coat of pva tomorrow and then i can add rivets.
need to think about the rest of the main wing next.
30 Jan 2015 20:43 #132 by Ex-Member
well the tailplane is covered and it has had two coats of pva.
the elevators have been sanded to shape and are now ready to cover.
so i started the rivets on the top side ( yes i know they should be flush and not dome, but dome looks better)
well there is 469 rivets on that quarter, so another 1407 to go.
31 Jan 2015 18:33 #133 by Ex-Member
finished the rivets on the tailplane and made up the rudder cores.
02 Feb 2015 18:31 #134 by Ex-Member
Been adding some stringers today to stiffen up the rear end.
hope to sheet most of the fuselage tomorrow and see so stiff it gets. fingers crossed.
02 Feb 2015 19:47 #135 by Quorneng
Some stringer are probably a wise move considering its huge size and the basic 'flexibility' of Depron.
Whilst the stringers will add stiffness you could loose some of the 'give' that Depron provides so it may actually end up a bit more 'crash' delicate. ;)
Time to create page: 1.328 seconds
