- Thank you received: 10722
Might just work on both of them as the Spit build doesn't excite me anymore
THE BLACKBIRD wrote: Because Owen it was a choice between the two I had already started a couple of years ago, ...........
I see now,
- Firewood
- Thank you received: 268
- boz
- Thank you received: 1420
- Firewood
So im getting it in the morning, so should see some progress on It this week,
Did a little sanding on the tail plane tonight but that's all
Going to be an interesting week doing this fibre glassing, never done anything this big before
Fingers crossed
All the cloth pre cut and numbered in sequence, the numbering soon went to hell as I got more and more stuck up with resin
Then I gave it coat of yellow gel, 25 euros a tin, when I opened it it was only half full
Now I normally let the gel go off some before I press on with the resin and cloth, but I did not know if this was the correct method so I went straight ahead with the resin and cloth this time, I always experiment with different methods, that's how I learn, well it was a mistake, so i don't know how it will turn out, I have my gut feeling I cocked it up, but will have to wait until I have done the other half before releasing it
Done
