Seagull 61" Sparrowhawk to be Christmas Build
As I said before, I dont like the "mushy" feel of expo, and dont loose sight of the fact that not all TX have it, and peeps still fly without it.
The Beard wrote: To be honest Gary Ive never noticed a problem with my models being twitchy or needing any mods.I normally set them up to manufacturer recommendations alfa male flies it, if he thinks its to resposive for me we knock the rates back until we are both happy and Im away,and enjoy my flying.
If that is the case Stephen, you must be setting your models up correctly. Well done that man!!
re the sparrowhawk tipping on it's nose, can you ease the legs forward a bit, get them further in front of the c of g, then you could back off the elevator throw a little.
As it is already touchy on ele's in flight, i wouldn't take the c of g back! That could leave you with a real pig to fly!
The other way is to release the model, while on the ground, with the engine idling, then gradually ease in the power, while holding in the up ele, this will give you a gentle pitch forward rather than the top rushing off and leaving the wheels in the grass, if you get my meaning.
The real Mew Gull, and others, were like that. If you just whacked the throttle wide, it would try to swap ends, from torque reaction, and tip over onto the prop.
- Phil Wood
- Inactivated User
The Beard wrote: Thats my collegue Ray holding the model but it nosed over.So we added more up elevator
Could you get away with fitting larger wheels?
Your strip may just be a bit too bumpy and large diameter wheels should smooth that out.
Worth a thought.
