3D printing Widgets
07 Jun 2025 20:20 - 07 Jun 2025 20:21 #136 by Eric
For foam, you can use five minute epoxy or UHU-POR. Polyester resin and most cyano's will 'eat' poly foam very quicky - and you will find you are trying to glue the magnet to a hole!
I don't know about print filaments, I don't know what will bond to it.
Last edit: 07 Jun 2025 20:21 by Eric. Reason: added a comment
07 Jun 2025 22:42 #137 by Quorneng
I use the same glue as I do on Depron.
It has the advantage that it dries rock hard in 24 hours, unlike UHU POR, so works particularly well to hold small components really rigid in foam.
Cyano is OK for PLA to PLA but not with most foams.
08 Jun 2025 06:26 - 08 Jun 2025 06:27 #138 by Eric
I've not heard of that one!
I looked it up on my browser, but cannot find that particular glue. The nearest one is in 20 mil tubes for about £4, and looks like it has rather nasty properties.
Danger!
Causes skin irritation. May cause an allergic skin reaction. Causes serious eye irritation. Harmful if inhaled. May cause allergy or asthma symptoms or breathing difficulties if inhaled. May cause respiratory irritation. Keep out of reach of children. IF INHALED: Remove person to fresh air and keep comfortable for breathing. IF IN EYES: Rinse cautiously with water for several minutes. Remove contact lenses, if present and easy to do. Continue rinsing.
It says it dries with a yellowish colouring. TECHNICQLL R-167 Universal Adhesive -30 / 80, Heat-resistant, light yellow, Capacity: 20ml Article number: R-167 EAN: TCHR-167
Is this the same one? If not, what is your source?
Last edit: 08 Jun 2025 06:27 by Eric. Reason: typo
08 Jun 2025 08:55 #139 by jon.in.swansea
Ah, I think I have a tube of that Techniqll!  Just the info I was looking for.
08 Jun 2025 13:34 - 08 Jun 2025 13:46 #140 by Quorneng
I get my Technicqll from ebay.
The latest just last week from an ebay store called VOYTO.
An ebay search "VOYTO Technicqll" will find it directly.
Technicqll do a range of different glues but for "foam safe" it has to be "Polyvinyl Adhesive" in the yellow and white 70ml tube.
I have bought a dozen or more over the years all from Ebay and post free!
Last edit: 08 Jun 2025 13:46 by Quorneng.
Thanks: Eric, Flytilbroke, jon.in.swansea
22 Jun 2025 17:20 #141 by Eric
Here's one for the 3D printer fans -
22 Jun 2025 17:31 #142 by Eric
Print info from -  www.eclipson-airplanes.com/mo...
22 Jun 2025 17:54 #143 by Klipkopwildlife
Some interesting planes there.
03 Aug 2025 13:17 #144 by jon.in.swansea
The availability of STL files for printing RC model parts has transformed how many folk get models into the air.  One of the classic exceptions when a printed part does not fit with other components in the model.  Tony had a shiny new set of STL files for their next exploration of the sky found that the nose of the fuselage was not a good fit for the spinner of the folding prop.  Rather than live with the extra drag I took it as a challenge to tweak the STL so he could get into the air.I have had the CAD files for some time, to not forget how I did it I created a YouTube video of the method.
The first trial with a truncated cone failed to split apart the STL file. A bit of lateral thinking created a solid body to use with a boolean cut to produce a variant STL that proved to be a good fit.   Hope that these notes might inspire others to adapt if you find a mismatch!
And, within reason, I would be happy to look at Aeromodeller's  STL parts that might work better if tweaked - no guarantee that getting a better fit might be possible given the many corners of FreeCAD I don't touch.
As usual, probably easier to see the tweaking process when viewed on YouTube rather than the thumbnail on the Aeromodellers web site.
05 Aug 2025 12:53 - 05 Aug 2025 12:55 #145 by Magpie
I've found a beginner's FreeCAD video which has enabled me to get off the ground, though I still seem to get stuck down cul-de-sacs and/or things don't work. I'm doing a mounting plate along the lines of the one for the FX707 but for my test rig. So far I think I've got an STL file for the backplate. It would be usefull if someone could verify it is a printable file. According to the video I should be able to return to the sketch but I cannot get that to work. His version is different from mine.
I have just tried to attach my file but because FreeCAD has saved it as an .FCStd it won't attach. So I need to find out how to save it as an .STL
Last edit: 05 Aug 2025 12:55 by Magpie.
05 Aug 2025 13:01 - 05 Aug 2025 13:02 #146 by Magpie
I've exported it to an STL file - Did that work?
This message has an attachment file.
Last edit: 05 Aug 2025 13:02 by Magpie.
05 Aug 2025 14:13 #147 by Klipkopwildlife
Sounds like you have similar problems with Fcad as I do. I've downloaded the stl, I'll try it.
Jon should be able to give you a link to a guy that uses the latest version of Fcad, it's a waste of time using anybody elses.
05 Aug 2025 14:58 #148 by Quorneng
Magpie
I think you will find that such files are not recognised directly by this site but can be down loaded.
This is a screen shot of your stl file down loaded from this site and onto my Free Cad.
So it works!
In Free Cad you do have to "Edit, Select All and Export" to create an Stl. The Stl is stored as a new file which not directly editable in FreeCad.
Note. As long as you have given the Stl exactly the same name as the original FCstd file both are stored adjacent to each other in the Free Cad file list.
Once you are looking at the Stl file in Free Cad you have to go back and open the original FCstd file to make any changes.
If you do modify the FCstd file remember to "Edit, Select All and Export as Stl" or the changes you have made won't appear in the Stl. It is one of the drawbacks of the file structure in Free Cad.
05 Aug 2025 16:09 - 05 Aug 2025 16:27 #149 by Magpie
I've managed to get back to editing the sketch & now the backplate has the screw clearance holes in it for the CF2822 & the A2212.
My main difficulty is adding the constraints, they seem to have a mind of their own and I cannot find some things like copying & mirroring.
The aim is to stick it onto some polystyrene & then onto my test rig arm so as to reduce the vibration.
The LE2204 has got me frightened!
Last edit: 05 Aug 2025 16:27 by Magpie.
05 Aug 2025 17:42 #150 by Quorneng
So it now looks like this also down loaded from your post!
I am not sure a piece of polystyrene will solve everything if the vibration is severe.
To be honest if it were me I would simply mount it rigidly on a piece of wood I could hold in my hand. The human hand makes a wonderful shock absorber and the LE2204 is a pretty small motor. Just be prepared to stop if you think it is getting to the point you can't hold it.
In the past I have have hand held an ED 246 Racer diesel fixed to a piece of wood and finger "flick" started it using the other hand.
Of course as a youth you are convinced of your indestructibility!
Time to create page: 0.268 seconds
