3D printing Widgets
- jon.in.swansea
- Thank you received: 1147
A suggested pattern for submissions might be:
a) a brief description
b) photo of the item in context of its use as well as a CAD view of the item
c) notes about printing
d) at a minimum the STL file
e) hopefully the CAD file (note these will likely need to be 'zip' files) and optionally notes about the CAD design
f) if contributor might answer questions or be amenable to tweak the CAD file for others.
Here is a device to secure motor cables - in a rough landing ESC, batteries, receivers can shift and drag wiring and disconnect motor wires. To save the faffing around out in the field I created a small device to secure the bayonet connections. It uses a rubber O ring to hold the bayonets in place.
In freeCAD I started with a main block and then cut away unneeded sections (hence the many 'cut' entities). I then added 4 separator blocks in the centre.
Typical printing settings are 2 perimeters, 10% infil, 2 layers top and bottom. Adapting the axis scaling would likely be all you would need to tweak it for different connector sizes.
Below is a photo of the device (normally Velcro'd to the fuselage wall) , what it looks like in freeCAD and the STL and CAD file (compressed).
Enjoy... I will await comments/suggestions prior to uploading more items.....
- Thank you received: 14148
I lost a new model like that, years ago, I hadn't realized that the motor was one of those silly little things that clamp into a top-hat that is bolted to the firewall. I'd read that the screws weren't very tight, so needed nipping up before flight, so I had done - but unfortunately the wrong screws! The motor, under load, rotated the opposite way to the prop until it had taken up all the slack in the three wires, burned through them, and shorted the speedo. The resulting detonation of the FET's blew a hole in the grp fuz! The burning remnants crashed to earth over the far side of the filed, and had pretty much burned out before I could get to it!
The mobile hangar stunk for weeks, after I'd put the remnants in to take home!
Further investigation showed that there was only one grubscrew in the top-hat mount, as well, instead of two.
For me, putting the heavy rotor behind the mount with the propeller in front reduces any gyroscopic effect there might be, if any.
- jon.in.swansea
- jon.in.swansea
Rather than lots of separate images pasted into the chat I created a couple of montages. Less space, words closer to images. The freeCAD and STL files follow the montages. Enjoy. -Jon
The front protection was a bit more complex as it could not be printed the same way in one piece so the halves were printed individually and angled by 3 degrees to the printer bed and then super glued together.
The front protection covered the top surface back 50 mm but also supported the leading edge profile. The rear covered 30 mm top and bottom. I judged the Depron surface in between would not suffer from the retaining bands.
Both covers matched the printed rib section but were adjusted for the thickness of the Depron skin.
More describing the principles involved but the stl files are available. Just give us a shout.
Such a narrow hold down is not ideal but was deemed acceptable in this case as the wing mount on the top of the wing pylon is quite narrow anyway.
- jon.in.swansea
Getting the files together for submission also encouraged me to tidy up the naming of the CAD entities as well as tweaking the thickness in the sketch for the leading edge so as to generate a more robust part. -Jon
- jon.in.swansea
Yuck, no way it is going to clean up in the field. Take it back, clean and dry. And when re-mounting the motor I fumbled over and over with getting the nuts and bolts in place. Argh! What I need is something better than my finger and better suited to the task than long pliers.
So here is my latest widget - there are two variants within the freeCAD and STLs. Should be adaptable if you get out your callipers and tweak the radius of the regular polygon and the shaft. -Jon
Have you thought of trying Exponential? I use it all the time, 30% to 50% it just softens the centre point nicely while still giving you full throw.
