Lancaster restoration project.
17 Oct 2017 17:31 #91 by Ex-Member
Replied by Ex-Member on topic Lancaster restoration project.
Bomb aimer/ front gunner has been glued in position and the nose dome fitted.
then i added all the nose windows and touched up the paint, i still need to add the rivets that hold the glass in yet.
but the nose section is starting to look good now.
i want to print the control column next and then add the dials to the instrument panel before i fit the canopy.
rear gunner is in position, mid upper guns are being made.
phew.
18 Oct 2017 21:03 #92 by Ex-Member
Finished the mid upper turret today.
i can finish the painting soon and then move onto the wings.
still it is another small bit done.
19 Oct 2017 19:00 #93 by Ex-Member
Still making a chair for the misses.
but i did manage to pick up some brown paint from B&Q, took a pilot in and had them scan his jacket.
then they matched the colour and mixed me up a batch of emulsion.
so now i have enough dark earth to paint the Lancaster and anything else i build.
we poodle plod along.
20 Oct 2017 12:57 #94 by Ex-Member
Second coat of brown paint applied this morning.
need to seal the fuselage once the paint has dried.
then i need to finish the cockpit off and glue the last two figures in.
so i have got a wing in. (wing ding) :P
First job will be to move the esc's so they ca get some cooling air.
from here.
to here.
then i can modify the moulded nacelles to allow for better air flow and then blend everything in nicely.
after that i suppose i will be adding rivets and repainting the wings.
soon be finished.
good
cos then i can finish the trent meteor off.
20 Oct 2017 16:56 #95 by The Beard
Replied by The Beard on topic Lancaster restoration project.
hi Tony have you enjoyed the refurb of the Lanc and are you going to maiden it yourself when its finished
20 Oct 2017 17:04 #96 by Eric
Replied by Eric on topic Lancaster restoration project.
Hi Tony, this topic has cropped up before - you want to position the ESC so that the airflow runs along the vanes.
As you have it positioned there, flat, it will be in 'dead' air, and won't get any cooling at all!
20 Oct 2017 17:33 #97 by Ex-Member
Eric.
it is either like that or buried inside the motor mount box, there is no where else to put it.
i was hoping that any air would be better than none at all.
i will have another think.
21 Oct 2017 00:29 #98 by Quorneng
Replied by Quorneng on topic Lancaster restoration project.
If there is room it would be ideal to mount the ESC under the motor box but as far forward as possible so the air traveled over it and out through a scale radiator exit shutter .
Thanks: Eric, Ex-Member, boz, Squirrelnet
22 Oct 2017 19:42 #99 by Ex-Member
There is just not enough room to fit the esc under the motor mount. :(
i have had to re do the mounts anyway as they were falling apart.
i have now repaired them and glued them back in place.
then i started riveting the underside of one wing.
while i was doing that i printed off a set of exhausts for the cowls.
back to riveting tomorrow and the refitting of the motors.
i hope to work on the other wing soon.
nearly there.
25 Oct 2017 20:07 - 25 Oct 2017 20:31 #100 by Ex-Member
well life got in they way of modelling until today.
finished the rivets on the underside of the wing.
then i flipped the wing over and painted it black.
i spent some time marking up the rivet lines and then started riveting.
had to stop as my hand was cramping up.
will do some more rivets tomorrow.
oops just noticed i missed a couple of rows on the wing tip, sorted now. :silly:
Tony ( sore hand) B
Last edit: 25 Oct 2017 20:31 by Ex-Member.
26 Oct 2017 06:47 #101 by boz
Replied by boz on topic Lancaster restoration project.
We are all behind you tony, your doing a great job, well done so far, keep plodding.
:) :) , boz.
27 Oct 2017 16:21 #102 by Ex-Member
Well i have finished all the rivets on one wing panel.
so i started slopping some paint on the upper surface.
It needs another coat of green yet and the roundel repainting, but it is starting to look ok now.
Rivets look ok.
i still need to blend in the cowls and rivet the nacelles yet though.
i am hoping to start the second wing on monday.
Tony (plodding on) B
27 Oct 2017 17:01 #103 by Mike Rolls
Replied by Mike Rolls on topic Lancaster restoration project.
I'm sure I saw one rivet out of line! :) Seriously - how many must you have applied - and how on earth do you keep them all so immaculately lined up?
27 Oct 2017 17:04 #104 by Ex-Member
well there is 32,000 on the fuselage.
not worked out how many will be on the wings yet.
pencil lines and luck, lots of luck, masses of luck.
Tony (shaky hands) B
27 Oct 2017 20:43 - 27 Oct 2017 20:43 #105 by Squirrelnet
Replied by Squirrelnet on topic Lancaster restoration project.
The wing looks really good, all those rivets are really worth the effort...all 5 million of them :P very nice work
Last edit: 27 Oct 2017 20:43 by Squirrelnet.
Time to create page: 0.222 seconds
