- Thank you received: 1978
Radios
- Flytilbroke
I had several questions about what happens next. My step son then asked "what is the long term prognosis" to which the consultant replied "Your step dad is nearly 79! At that age there are too many things that could go wrong to consider the long term. Now that makes you feel really old.
On the other hand the consultant did say don't worry everything is under control and going to plan.
Oh well! Nil desperandum
- Flytilbroke
- Thank you received: 10722
- jon.in.swansea
- Thank you received: 1164
of your brain cells.....
www.4-max.co.uk/batteries.htm
I have not looked at the price of balsa yet but no doubt its sky high as well, the price of the radio gear was very good i thought
Just had a letter from an insurance company that want to pay me out on a policy iv had for years and it always paid me so much a month, but because the original letter went to an old address, my lost sons, it got to me late and they received my reply i a day late and now they refuse to pay me out, crooked all of them
My daughter in law is very disappointed she must have had designs for it
There seems to be a lot of different versions and lots of second hand out there and some seem to be good buys, not that iv ever bought second hand and was a Futaba man, i bought my first Futaba in the 1960s it had a 4 Ch yellow Tx and it came with Rx and 4 servos
- jon.in.swansea
The FrSky ecosystem includes open source software which is kind of interesting along with voice / haptic feedback. Quick look at manuals for a few of these seemed rather more concise than the 160 pages of the Futaba manual.
Currently 8 channels is good enough and I am not going to be doing long distance and much beyond setting rates and limits and differentials I suspect many of the products will have excess functionality. The FrSky does seem to support at least some telemitry out of the box - like Rx voltage which I am not getting from the Futaba (yet).
A couple of FrSky transmitters I have been looking at:
Taranis Q X7 Access roughly 125.00 quid, bit more with battery
* Dimension: 202.2mm*189.4mm*96mm
* Weight: 613g (without battery)
* Number of channels: 16 (ACCST D16) / 24 (ACCESS) channels
* Internal RF module: ISRM-N
* Operating Voltage Range: 6.5V~8.4V
* Operating Current: 160mA@7.2V typ
* Operating Temperature: -10℃~60℃ (14℉~140℉)
* Backlight LCD resolution: 128*64
* Smart Port, Micro SD card slot, Mini USB Port and DSC Port
* Compatibility: ACCST D16 & ACCESS receivers
Some links I have been looking at....
www.flyingtech.co.uk/product/frsky-taran...s-radio-transmitter/
The Rx choices seem to be rather pricy and not included in the box. I have not gotten my head around ACCST vis D15 vs ACCESS vs 3rd party
suppliers of Rx.
_______________________
The other one I looked at is Taranis X9 Lite - a bit smaller, less expensive. Not a bad looking beastie but the battery choice a bit clunky and the box does not seem to come with a receiver:
* Dimension: 184*170*101mm (L*W*H)
* Weight: 505g (without battery)
* Operating system: ErskyTX / OpenTX
* Number of channels: 24 channels
* Operating voltage range: 6.0~8.4V
* Operating current: 190mA@7.4V
* Operating Temperature: -10℃ ~ 60℃ (14℉ ~ 140℉)
* Backlit LCD resolution: 128*64
* Model memories: 60 models (expandable by Micro SD card)
* Smart Port, Micro SD card slot, Micro USB Port and DSC Port
• Compatibility: ACCST D16 and ACCESS receivers
93.90 inc VAT.
Recommended receiver (ACCESS Rx):
* FrSky R-XSR * RX6R * RX4R
www.unmannedtechshop.co.uk/product/frsky...-2-4ghz-transmitter/
Seems like I need to get several Rx to limit the stress on the beasties of shifting from model to model. My current lack of knowledge about FrSky Rx options is limiting me. The ACCESS limits the Rx choice, but other protocals mentioned. And it would be nice to reliably be able to use 3rd party Rx such as:
www.unmannedtechshop.co.uk/product/radio...-6ch-frsky-receiver/
So really would like to pull from the collected knowledge of the group....
www.t9hobbysport.com/?srsltid=AfmBOorHUL...-jEIMijiV0uuk0tIzVDg
I'm using Taranis transmitters, and mostly X8R receivers, although I have a couple of X6 and one X4, for smaller models.
TX and RX are sold seperately, because you then have more choice of how many channels you really need - and all can be reprogrammed for different operating systems anyway, for a nominal sum, when you buy them - at a fraction of the cost of a Futaba, or other top-name set - that does exactly the same thing!
Details on the website.
All I can add is that I've had 100% reliability in all kinds of models, ranges, and conditions.
There are plug-in modules for all kinds of things, from flight-pack cell voltages, altitude, variometer, and so on.
It takes a little time to learn and understand how to set the gear up, but once done, it is straightforward and lots of how-to's on the Tube if you get stuck!
