Model Aeroplane Video's
19 Feb 2012 20:44 - 19 Feb 2012 20:45 #226 by Quorneng
Replied by Quorneng on topic Re: Guess the Aeroplane (just a bit of fun.)
Thanks admin
I will try another one. Any ideas?
Certainly not a 'one off' but it is restored hence the Bell UH1 in the background!
Last edit: 19 Feb 2012 20:45 by Quorneng.
19 Feb 2012 21:33 #227 by Eric
It looks like a commandeered Swordfish! (with the centre hole covered over).
19 Feb 2012 23:04 #228 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Guess the Aeroplane (just a bit of fun.)
It's not an Arado 64a is it?
19 Feb 2012 23:57 #229 by Quorneng
No not an Arado.
Clue.
It is not at all what you expect it to be!
20 Feb 2012 00:00 #230 by Eric
Avro 504?
20 Feb 2012 00:17 - 20 Feb 2012 00:18 #231 by Quorneng
No
Its not that old and I don't think the 504, or any of its derivatives, ever had sweep back on its wings. Thats a hint.
Last edit: 20 Feb 2012 00:18 by Quorneng.
20 Feb 2012 01:11 #232 by Eric
Then it's a Stampe with a radial engine!
20 Feb 2012 02:27 - 20 Feb 2012 02:30 #233 by Quorneng
Good try Eric
You know that beautiful streamlined light bomber that was faster than the RAFs then best fighter, the Bristol Bulldog?
This is what you get when you put a Bristol Pegasus radial on the front of a Hawker Hart -yuk!
They also had to increase the area of the fin.
Only for the Swedes but they liked it enough to build it under licence.
Last edit: 20 Feb 2012 02:30 by Quorneng.
21 Feb 2012 07:07 #234 by Quorneng
Just as a follow on, that Swedish Hart would have had 9 of these in it.
An exhaust valve and a piston gudgeon pin from a Bristol Pegasus.
My Dad collected bits as well!
22 Feb 2012 03:54 #235 by Quorneng
How about this then?
I have painted out the registration!
26 Feb 2012 01:42 #236 by Quorneng
Oh well never mind!
McDonnel 119/220.
A interesting plane none the less as it was the last McDonnel built (1959) before their merger with Douglas.
The two model numbers are a bit of a misnomer as they actually refer to the same aircraft as only the prototype was ever built.
Unique at the time as a business jet having 4 turbojets slung under the wings but the low ground clearance meant special square intakes were required to reduce the likelihood of the engines sucking foreign objects off the runway.
It still exists.
26 Feb 2012 16:28 #237 by Klipkopwildlife
Sorry Simon, I was busy on this one, but spent too much time on it, only got back to it today!
14 May 2012 01:39 #238 by Eric
How many of these can you identify - without using the pause button!
Don't waste space trying to list them all on here!
  • Seamus O Leprosy
  • Senior Member
  • Senior Member
14 May 2012 02:00 #239 by Seamus O Leprosy
Replied by Seamus O Leprosy on topic Re: Guess the Aeroplane (just a bit of fun.)
Was it a Spitfie?
I don't do smilies :-(
14 May 2012 02:23 #240 by Eric
er..... no! :P
Time to create page: 1.300 seconds
