- Grumpy42
- Thank you received: 14473
Can you identify these?
This one should be easy
Boeing 314
Northrop F5E
Witman Tailwind
- Seamus O Leprosy
- Senior Member
- Thank you received: 38
and what Klep said
I don't do smilies
- Sangoma
The early BD 4 had an interesting wing construction. Each rib had a short panel of the wing attached to it. The wing was actually built up by sliding them over a circular spar and fixing them together.
An ideal technique for a carbon fibre tube spar.
- Grumpy42
