FT Saab Viggen 70 mm EDF.
A few extra grams of weight is less problematic than a dead esc at 100 feet agl!
I overloaded an esc once, in a pre-bult plug n play - it blew a hole in the fibreglass fuz! (and it stunk!!!)
- crash happy
- Thank you received: 1203
Klipkopwildlife wrote: I would question limiting the throttle travel, that's what your left hand's for![badass]
Normally I would agree with you Klippy, but in this case there is a solid reason for it. As Eric pointed out running the ESC at max capacity is asking for trouble. As it is buried in the duct behind the battery box, to change it & the wiring would require a lot of surgery! Seeing as there is no way I am going to need 440 w/p if I use a 4s, the simplest solution is to restrict the throttle so the ESC can only draw around 60 amps. That would still give in excess of 300 w/p at full chat ! :woohoo: Anyway my left hand is reserved for lifting pint's of beer !
STF. Apologies, I have just seen your comment. Something consider when I build the next one !
Do be careful.
An ESC pulses the power so restricting the throttle does not physically reduce the amps but just the length of the pulse. It is the peak amps driven by the full battery voltage (4s in your case) that troubles the mosfets. What works once may not over a longer period.
The ESC pulses are fast and there is some reluctance in the circuit so it does take a measurable length of time for the amps to build up thus reducing the throttle will reduce the peak amps per pulse but not in direct proportion to the throttle setting.
It would be nice to think every ESC is quality tested to determine its capability for both amps and volts, but there are not, so they fall in to a range of capability.
The guide for reliability is to have the full power amps at no more than 80% of the ESC amps rating particularly if the battery voltage is also at the ESC's upper cell limit.
- crash happy
What you propose would certainly stress the ESC a bit more than a set up that took 60 A at 100% throttle.
I am not suggesting it will cause a problem but more stress increases the risk of a failure.
OF hasn't done anything wrong, he started a post and then decided not to complete.Eric wrote: What has Mr Admin done wrong?
Oh dear, I've tried to keep this simple and failed!
The bottom line, it's better to use an ESC that's rated up to 6s if you want to run a 4s, regardless of the current required. The caveat of extra current headroom on the current is to cover events sometimes beyond your control, ambient temperature, cooling air etc.
Now I'm going to do your head in, when long supply runs are required in an ESC setup, the weight of the electrons rushing down the wire becomes a problem when the output circuit shuts off![badass]
Oh never mind! [badass]
- crash happy
P.S. I got the joke Eric :lol:
It would be nice if I (we) could delete our own accidental posts.
Err, I think you can, but you have a limited amount of time to do it, perhaps we need to ask Admin to lengthen the time window?old fart wrote:
Sorry Eric, the Shingles affects my sense of humour, my story and I'm sticking to it![badass]
- crash happy
