FT Saab Viggen 70 mm EDF.
- crash happy
- Thank you received: 1203
I can certainly see the similarity, the difference is, I don't think you could cultivate mushrooms on mine !
- crash happy
- crash happy
I did manage to get most of it off where the ridge fits, & the area behind the EDF where the thrust tube goes. I left the ducts alone to keep the surface as smooth as possible. It became obvious that another solution was required. As an experiment I made a copy of the battery box cutout in the extruded foam I had cut down to 5 mm sheet. I can't weigh it at the moment ( scales broke) but even in the hand there is considerable difference, I would guess it weighs 50% less ! Although I can't make the whole airframe with it, It won't fold without splitting, I decided to use it anywhere I can. The battery box, being internal, was a prime candidate. Also the top ridge, covered on the outside with brown paper & diluted wood glue, is far lighter then the original. I may well use the same method on the canards & tail fin, not sure about the wing though, as such a large area of flat plate will be prone to warping , we shall see !
One final problem, I can't find a 70 mm EDF in europe for love nor money !
- crash happy
On the plus side I went out & bought a new set of scales this morning, the results are interesting. That explains a lot ! Think I had better cut down some more foam ! :whistle:
How much weaker is the lighter foam?
Is the strength/stiffness of the foam important for its application?
- crash happy
Quorneng wrote: The next questions are:-
In it's naked form, quite a bit weaker, but once covered with brown paper & wood glue remarkably strong. The plan is is for the battery box, EDF & thrust tube mounts to be in bare foam as they have plenty of internal support. The tail fin, canards & ridge will be in covered foam. As you can see from the photo I made the tail fin, slotted it & flush fitted a carbon tube with epoxy for extra stiffness. Now covered it is extremely stiff & still weighs considerably less than the original.
- crash happy
Combined weight of all these parts 58 grams, I estimate that to be a saving of close to 50 % !
- crash happy
At least now it's on the way, albeit by slow boat.
