- Thank you received: 1048
3D printing Widgets
- Magpie
My flight trainer messaged me that he was back from his caravaning wanderings just as I was going down with it but hopefully I can get back in the air next week.
Meanwhile back at the ranch I've been working on FreeCad & Cura & have learnt alot of new tricks.
I had to replace the room thermostats, mainly because of the plastic crumbling, so I printed some adapter plates which was quite usefull.
My son has been buying Transformers (the 1980s toy) with missing parts off Ebay & cannibalising them to make some whole again. When he heard about my printer he downloaded STL files for the missing parts & I've been printing them out. Some were easy but others weren't & I've been trying to use supports & the support blocker which gave mixed results. I've also ordered some smaller nozzles to see if that helps with the finish as the parts are quite small & will have to get more organised on setting files.
I've been able to import the STL files & graft on additions but some things are proving troublesome. It seems that chamfers & external fillets are a well known problem which hasn't been solved.
The addition on this had to be done using the revolver function as the chamfer refused to be exported. I tried remaking it & 3MF & OBJ formats without success.
- jon.in.swansea
- Thank you received: 1192
- Magpie
After we got clear of the covid we must have been first in the queue for the latest flu so that took another 2 or 3 weeks to run its course.
I got some 0.2mm nozzles & got some decent results on the transformer parts which actually fitted very well on the toys.
The offspring are coming round next tuesday to collect their presents so I printed some labels. They're all into Star Trek so I downloaded a Klingon font to do their names in which will keep them occupied for a little bit translating them.
Decent plant labels are like hen's teeth, they are difficult to write on & fade in no time especially as some of my plants need at least 3 years. So I printed some, the names are recessed 0.4mm. I tried filling them with coloured wax but it tended to stick on the surface so I had to resort to inking them in. At least if the ink fades the names are engraved so will persist.
I had intended to go on a course at a local community thing to learn about using laser cutters & use their machines to make some parts but they don't seem to be running any so I've printed out some formers for the nose section. I don't know how much heavier filament is than ply.
- Magpie
F5 has a few bits attached to bits, only the three main cut-outs are part of the base pad, the rest are pockets. The wire frame message kept popping up & takes some clearing. Altering one pocket sketch often broke another, it kept losing the face plane & sometimes I had to revert it to the X-Y plane & alter the attachment position. Also to get the square cut-outs for the stringers evenly spaced took a bit of thinking about & a few attempts.
- Magpie
But the real reason for logging on is that I'm back in the temptation zone for a Laser cutter.
I've been looking at an AtomStack one. There are two versions on Aliexpress, 10W & 20W, in round numbers £215 & £300.
Would the 10W one have enough power for Balsa & thin Ply?
I have a 2.5watt one that cuts through chicken wire at 3 metres! The trick is to not have to repeat the cut because then you burn the bed, there are hone comb beds available, I guess it's all about how much, how long and how fast! ie, experience.
I bought 3 mirrors for mine but still have to get the whole thing rigid enough!
- Magpie
There are honeycomb beds for underneath the material & then I've read a ceramic tile underneath that will absorb the left-over energy.
One review says to recut at lower powers for the best cut. That would obviously depend on the repeatability of the machine.
- Magpie
I worked on metal-cutting machines & they needed alot of torque so they had servo motors & leadscrews. We did alot of retrofits on old machines so they needed to be laser calibrated.
I also worked on some roll lathes where size didn't matter much, they mainly just smoothed out the dents, & the Y-axis was controlled by feedback from the grinder wheel current.
- Magpie
I printed out the downloaded version with the reduced base, & they turned out quite well. I dropped the first one on a tiled floor & it broke in half which surprised me.
I was asked if I could do them in different heights so I downloaded the small top piece with the studs and redid it all on Freecad, just using that so I could alter the different bits.
I had tried to split the original into its componts using Mesh Design but it didn't work, I just got more component objects but none of them were actual separate components.
I have run out of Black PLA so I'm using the Silky Gold left over from Christmas.
Having had the table-marking problem I've been using Scotch Blue but it lifts off the table & the thin parts warp so I changed to Mat Adhesion directly onto the bed. The original printed OK but the first redesign came loose from the mat as it got near the top.
So I made it shorter, the base slightly larger & printed it without the mat.
I've modified it on Freecad to give a steeper angle to the top & that's printing it out now.
They take about 3 hours to print & the team have six cars between them so the printer is going to be busy.
- jon.in.swansea
Nice hybrid (bit of download, bit of your on work) CAD workflow.
- jon.in.swansea
The finished sink....
I am so looking forward to clearing the man-cave of the building materials so that I can get back to some RC stuff...
