Vickers Wellesley
02 Jan 2018 19:39 #61 by Mike Rolls
Replied by Mike Rolls on topic Vickers Wellesley
That looks really impressive! Well done!!
03 Jan 2018 19:52 #62 by Ex-Member
Replied by Ex-Member on topic Vickers Wellesley
Other side of the cowl constructed today.
fits nice and i think it will look perfect once sanded and painted.
started the inner flaps as well.
waiting for some more 1mm depron to finish off the detailing.
03 Jan 2018 23:14 #63 by boz
Replied by boz on topic Vickers Wellesley
Looking great tony it's coming together very nicely. :)
05 Jan 2018 12:23 - 05 Jan 2018 12:23 #64 by coleighf
Replied by coleighf on topic Vickers Wellesley
Hi Tony. Have you got the Warpaint Series No.86 book on the Wellesley by Ian White? See attachment. It's the best reference I know and includes some great interior photos on pages 38 and 39. Also be aware that despite being generally docile, if it went into a flat spin from a stall it wouldn't come out of it. Spins were banned, but if you look at Jeffrey Quill's book "Spitfire, A test Pilot's Story", he describes on p
ages 100/104 how K7737 did this to him on a routine test at 12,000 ft. He did everything he could and it wouldn't come out, so eventually he had to jump at 3,000ft. Later a RAF test pilot was killed during routine stall tests when K7729 did the same thing. On my minimal indoor version I enlarged the tailplane and put in some wash-out, it flies beautifully. I just thought I'd mention it. The model looks brilliant and I admire your patience in reproducing the geodetic framework, it's the way to do it.
Last edit: 05 Jan 2018 12:23 by coleighf. Reason: Typo
Thanks: Klipkopwildlife, Ex-Member, Quorneng, boz, Squirrelnet
06 Jan 2018 16:58 #65 by Ex-Member
well my 1mm Depron turned up, so i have spent today cutting strips out for the undersides of the wings.
i also glued the cowl together and stuck it to the engine, so that's another job out of the way.
my silk has been despatched as well, so i am getting very near to covering time. :unsure:
just got the dreaded u/c to sort out.
06 Jan 2018 17:09 #66 by coleighf
Absolutely brilliant Tony. Are you still using thinned PVA for putting the covering on top of the Depron?
06 Jan 2018 17:45 #67 by Ex-Member
not any more sir.
diluted Ronseal diamond hard floor varnish is my preferred muck now. :silly:
06 Jan 2018 17:48 #68 by coleighf
Thanks, I must try that.
06 Jan 2018 22:27 #69 by Quorneng
Replied by Quorneng on topic Vickers Wellesley
Tony
I am intrigued to know with only 1 mm clearance whether the covering (tissue?) will sag when the varnish is applied and end up sticking to the Depron sheet inbetween the geodetic strips or is that what is intended to happen?
06 Jan 2018 23:18 #70 by Ex-Member
that's the plan sir, i am aiming for uneven sagging.
as i feel the covering on the full size would alter tautness depending on the weather.
07 Jan 2018 13:49 #71 by Firewood
Replied by Firewood on topic Vickers Wellesley
One of my dislikes with Eze-Dope on a one 1/16 square built up tailplane stuke one tissue surface to the other,maybe the answer would be to spray several thin coates.Another thing you might try is color into the floor seal to save a lot of painting later.
13 Jan 2018 19:08 #72 by Ex-Member
i have covered the wings with silk and ronseal.
it looks to have shaped fairly well to the fake geodesic structure, not as well as i had hoped though.
still it will look ok from a mile or more away.
painted as usual with emulsion paint.
we plod on
13 Jan 2018 19:38 #73 by Squirrelnet
Replied by Squirrelnet on topic Vickers Wellesley
Looks pretty darn good to me Tony, nice work !
13 Jan 2018 20:22 #74 by coleighf
It looks as if it’s worked pretty well to me. I’d certainly be pleased with that.
14 Jan 2018 06:24 #75 by boz
Looks good so far, keep plodding :woohoo:
Time to create page: 0.987 seconds
