Vickers Wellesley
the undersides have been painted and the reg numbers are now being painted on.
side stringers going on.
i am now printing out the formers for the underwing bomb racks and hope t get building them over the next few days.
but i need to do some 3D design work for Lancaster parts, so it might take longer.
we plod on
i started by printing out some formers and then glued them to some 3mm depron cores.
the resulting construction is now being covered with more 3mm depron and then the two halves will be joined together.
I need to make the, knock off in case of bad landings,so i shall be making some ply and magnet fittings later.
Thanks
- coleighf
- Junior Member
- Thank you received: 57
i shall just make them and fit them and hop for the best.
at least if they are removable i can just take them off if they cause problems.
- coleighf
- Junior Member
www.britmodeller.com/forums/index.php?/t...ckers-wellesley-mk2/
the idea is to have a box on the panniers that will slot over the mount and then it will all be held on with magnets.
they slot on over the wing tubes and will be glued home later when i am happy with everything.
I just need to finish making the panniers now.
we poodle on
I think we've all seen that vid where a Skyhawk dropped an external fuel tank, but it flipped up over the top of the wing, collided with the chase plane, and took it's wing off!
- coleighf
- Junior Member
- coleighf
- Junior Member
At the time the bombs would have been manually loaded so it was important that the panniers were reasonably close to and parallel to the ground when the Wellesley was sitting on its undercarriage.
