Trent Meteor for 2015 start.
24 Feb 2015 17:25 #166 by Ex-Member
Replied by Ex-Member on topic Trent Meteor for 2015 start.
One aileron finished.
need some more control horns before i can do the other one. :(
12 Mar 2015 20:41 #167 by Ex-Member
Both ailerons finished and ready for sanding and covering.
we are back on her.
12 Mar 2015 21:00 #168 by Quorneng
Replied by Quorneng on topic Trent Meteor for 2015 start.
You are moving those huge aileron by those tiny horns?
12 Mar 2015 21:09 #169 by Ex-Member
Full size horns mounted to plates glued to the centre core of the aileron.
if they don't work, won't take much to chop them out and replace.
13 Mar 2015 16:18 #170 by Ex-Member
well they fit anyway.
weather they work will remain to be seen. :P
need to bite the bullet and fit the wing tubes next, or i could do the main section to fuselage mounts. :P
14 Mar 2015 16:08 #171 by Ex-Member
Fleshed out the wing tips this morning.
and then started on the jet nacelles on the underside of the centre section.
Takes ages to get anywhere with this brute.
16 Mar 2015 17:48 - 16 Mar 2015 18:01 #172 by Ex-Member
well i have added extra bracing round the wing tongue to give the sheeting something to stick to.
I then spent the rest of the day cladding the ribs that touch when the wings are joined.
the idea is to give a solid surface to help the joint stay true.
Last edit: 16 Mar 2015 18:01 by Ex-Member.
19 Mar 2015 08:45 #173 by Ex-Member
Just planking the underside of the nacelles at the moment.
i hope to get the main wing to fuselage mounts sorted next week, then i can finish and cover the fuselage ready for 10,000000 rivets to be added.
:silly: :silly:
26 Mar 2015 19:21 #174 by Ex-Member
cut the slot for the wing tongue today and that's it. :(
26 Mar 2015 21:20 #175 by Garry Pollard
Replied by Garry Pollard on topic Trent Meteor for 2015 start.
Maybe if you are not in the mood it could be just as well Tony
26 Apr 2015 19:22 #176 by Ex-Member
had a stressful day fitting the nose locating tubes.
but they are done now and the nose bolts on quite well.
need to cut the slot to take the wing tongue next and then i can start the wing fairing and finish sheeting the fuselage.
26 Apr 2015 20:49 #177 by Ralpharr2001
Replied by Ralpharr2001 on topic Trent Meteor for 2015 start.
By 'eck lad that's big!!
Superb! I didn't think depron would be strong enough. Great job. Can't wait to see it fly.
26 Apr 2015 20:54 #178 by Ex-Member
i'm not sure it will be strong enough. :unsure:
but if you don't try you will never find out and i dont like to play safe. :)
26 Apr 2015 21:07 #179 by Ralpharr2001
I like your style Tony. Nothing ventured, nothing gained. [badass]
26 Apr 2015 22:34 #180 by one tenor
Replied by one tenor on topic Trent Meteor for 2015 start.
Blimey Tony, have you built hangar for it yet? a couple of Norton 500's up front maybe :lol: :evil: Great job so far and looks pretty strong. What about weight comparison to conventional build or is it too soon to know?
Time to create page: 1.364 seconds
