- Thank you received: 10722
1966 Pattern ship
Looking good though, and very quick,
I recognise, but can't at this moment, name the other model in Tony's pic. It might be one of Phil Kraft's fleet.
there is a 1/2 balsa and ply brace across the front.
2 1/2 balsa webs at the spars and there will be a hardwood brace/ mount at the t/e.
though i think a glass bandage round the middle might be an idea for peace of mind.
Well i am plodding on with sheeting the wing, 10 sheets of 1'6mm balsa later.
the other one is a lancer sl-62 by Sterling of philadelphia.
Finished fitting the fuselage formers and started planking.
making up the battery hatch.
planked.
Hatch off.
Just having an offer up.
Made up the battery tray, not fitting it yet until i am sure where to put it.
made up the servo tray as well.
need to sort out the elevator joiner, it is supposed to have 2 control rods, one for each elevator.
i want to fit a rod joiner with a central horn inside the fuselage.,
need to find a supplier of one as i cant silver solder.
the mark 8 has a split elevator.
the plan has no suggestions on how to do it.
the elevator of course is swept back.
so.
do i use 2 control horns and 2 rods joined together.
or do i get a torque rod to join them together
or do i get a torque rod with a central horn.
and can you buy them ready made as my silver soldering is shite.
confused.
i need to do it next before i can finish sheeting the underside of the fuselage.
just want something that will be safe and strong and simple to do.
glued the tailplane on and built up the rest of the fuselage tail.
Then we stuck the fin on.
and while the superfast glue was drying i cut out and sanded down the rudder, hinged it and pushed it in place.
The we cut out and shaped the elevators, hinged and pushed them in place.
Just for a laugh i clamped the wing on and took some pictures.
Hopefully back to the wing tomorrow.
