1966 Pattern ship
24 Jan 2013 20:11 #46 by Eric
Replied by Eric on topic 1966 Pattern ship
Every time I see this model as the construction proceeds - I think - God, that nose is short! Then I recall it is significantly swept-wing, and the c of g at the root will be somewhere near the trailing edge!
24 Jan 2013 20:23 #47 by Ex-Member
Replied by Ex-Member on topic 1966 Pattern ship
c of g is right at the t/e of the wing, so the nose is quite long really.
24 Jan 2013 22:44 #48 by Ex-Member
A bit of blue on now.
need to wait for it to dry and i can do the other side.
26 Jan 2013 00:31 #49 by Ex-Member
well the main wing has been sealed and got the top covering on, once dry i can turn it over and cover the underside.
need to brave the snow tomorrow and make the u/c legs.
Got the first coat of paint on the fuselage now.
can do the second coat tomorrow and then seal.
26 Jan 2013 21:19 #50 by Ex-Member
wing is covered and drying, 2 more coats of sealer to go before paint.
u/c legs are on and drying.
fuselage has the second coat of white and red done, only blue to go.
with any luck i can get all the sealer on the wing tonight and have it ready for paint in the morning. :P
26 Jan 2013 23:26 #51 by Ex-Member
u/c
fuselage drying.
[badass]
27 Jan 2013 22:23 - 27 Jan 2013 22:24 #52 by Ex-Member
Had a real rubbish day today, everything went wrong. :(
got the wing dowels in the nose sorted, eventually. :angry:
cant put the wing bolt plate in until after i have sorted the rudder servo as it hides the servo mount. :angry:
so i hinged the rudder and elevators and tidied them up paint wise.
then did the red on the top of the wing.
Then we did the blue on the top of the wing, got the white to do later. then when dry i can flip it over and do the underside.
thinking of only having red and blue on the underside to aid with orientation.
Last edit: 27 Jan 2013 22:24 by Ex-Member.
28 Jan 2013 01:37 #53 by Garry Pollard
Replied by Garry Pollard on topic 1966 Pattern ship
That looks evil Tony, cant wait to fly it
28 Jan 2013 01:43 #54 by Ex-Member
i best get it finished then.
:P
28 Jan 2013 18:38 #55 by Phil Wood
Replied by Phil Wood on topic 1966 Pattern ship
I like that up front cockpit, seems to add that touch of finesse to the styling.
Cracking job Tony, well done mate. ;)
28 Jan 2013 21:13 #56 by Ex-Member
Right'
i done me chores this morning, (cleaned the bathroom and cut logs for the fire) so after lunch i got down to doing something.
Got 2 coats of sealer on the fuselage, the third coat will be done after it is fitted out.
then we got the first coat of red on the underside of the wing.
then we slopped some blue on.
once it is all dry i can flip it over and do the white on the upper wing.
then it is a case of second coat of paint, fit the ailerons and 3 coats of sealer.
fit out and finish. :cheer:
28 Jan 2013 21:58 #57 by Eric
Tony put - c of g is right at the t/e of the wing,
So, unless I'm seeing things, the main legs are slightly IN FRONT of the c of g! You've made a tail-dragger with a nose leg! :woohoo:
28 Jan 2013 22:53 #58 by Ex-Member
as per plan eric, will check c of g later, cannot be bothered at the moment.
maybe i best not post anymore build threads as i keep doing everything wrong. :(
28 Jan 2013 23:26 #59 by old fart
Replied by old fart on topic 1966 Pattern ship
Tony, if you are building as the plan says then you are doing it right, keep it up you're doing just fine. :) :) :)
Thanks: Garry Pollard, Sarah-Jane Smith
28 Jan 2013 23:42 #60 by Garry Pollard
If there is anything wrong with the model, no doubt the owner will post on here, and as I am the eventual owner of this one, I will certainly post a report.
If it is anything like the rest of the models Tony has built for me it will be 100%.
Time to create page: 0.220 seconds
