EDF Problems in SR71 Build.
- Phil Wood
- Inactivated User
The Beard wrote: I do feel you have a warranty claim BB as poly says the shaft has pulled out of the motor most likely because it wasnt sufficiently secured
I'm not sure how it works with regard to warranty,..... who's responsibility is it to make sure that retaining collets, (if used) are tight?
I've seen a few motors that use use circlips that are clipped into a groove on the shaft.... if this was the case then the clips should have been able to stand the force.
We're not talking a lot of force here,... it's only the static thrust generated by the fan/prop
- Thank you received: 10722
The motor has two grub screws at the back and front ,
I told them it's a bit late for that and on a motor this expencive i should not have to check and if i did and got locktight on the motor the quarantee would be null and void, waiting a reply
- Phil Wood
- Inactivated User
THE BLACKBIRD wrote: I did not realise my incompetance with the leccy warranted it's own thred
I hope that is meant in jest BB.
I know sod all about electric flight, but I am a bit of a scientist & some of my skills are transferable ... this means I can often spot a problem on equipment that I've never seen before.
How do Scorpion expect you to check the grub screws now? .... once the shaft has been withdrawn, the screws should be loose. !!!!
Whichever way you look at it, that shaft should not have slipped the screw unless someone has loosened it!
If that fan had injured someone when it flew off, they'd be looking at a personal injury claim for selling unsafe goods .... just as if they'd sold a car with faulty brakes.
Why not get a bit tough with them & hint that you may get the motor inspected by Trading Standards .... I'll bet they JUMP!
I have never seen one of these fans, but on a normal outrunner motor, the shaft is held by a circlip, to stop it pulling out, BUT also in the pack is a collett , the type that notmally holds wheels on, and they advise you to fit that to the shaft also. So this begs the question, is the circlip enough, as the collett has only been included recently ????
Also must agree that the grub screws should have been tight when the unit was bought. If you buy a new car, do you go round checking every nut and bolt?? No you dont, so why do they ask if the grub screws were tight??? Thats their job , not the end user
- Phil Wood
- Inactivated User
Garry Pollard wrote: Good point Pol!!!
Quite right Garry... there's probably no difference in the design of expensive motors & the cheap Chinese copies, ... I'll bet most of them are built in the same sweat shop & then branded.
The one thing I would then expect from an expensive supplier is quality control.
I think BB should demand compensation for the motor, & the damaged fan & tacho.
Any company can have faults but it's how they deal with them that decides how good they are.
Horizon Hobby would have had replacements for everything in the post the next day !!! ... that's why they continuously get the praise.
I think BB should e-mail them a link to this thread.
Cannot go wrong with a peice of wood.
- Phil Wood
- Inactivated User
THE BLACKBIRD wrote: ME !!! How the hell do i email a link from the thred, your talking to a dumbo here, i want to put the emails on here but dont know how, i know nothing about computers and apparently electrics.
It's easy BB ... we'll explain how in a different thread as soon as I get chance.
If you want to post your emails from them into here, then just open their e-mail, highlight the text you want to copy, right click your mouse & you'll see the word "Copy"
Then start your post here, right click the mouse & select "Paste"
All the text you highlighted will appear in your post.
Give it a try .... if you mess it up we can just delete it.
I took the motor apart it look's ok (to me) and put it back together useing thred lock, there is a circlip at the front no grub screws, two grub srcews at the back one of them going onto a flat on the shaft.
suppose the clip at the front is for when i reverse
On the beach this time
found bits of the tacho im putting it back together at the moment
I WILL NOT BE BEAT
Just under it like this) is
((arrow in a circle pointing left)) www.modelchat.org.uk/forum/technical-stu...-build/post?do=reply
Just put your mouse cursor on it, hold the left clicker down, and wipe the arrow along the words. They will go blue. Let go of the left, and click the right, you will get a box with 'copy', and some other bits, left click copy.
Go to the email, put the mouse cursor where you want the link to go, and left click, then right click. You will see a box with 'paste', and others. Click paste, and the words of the address will appear. Job done.
- Phil Wood
- Inactivated User
just paste that into you e-mail or maeesage.
left.
going back to my origanal plan of two lander 120mm fans, only problem is no one seems to have any, i need your help to locate them if you would please.
I WILL NOT BE BEAT.
Ideally the screws should be at 90o to one another, but they rarely are.
www.tporder.com/list.asp?ProdId=0105
compare.ebay.co.uk/like/170557537693?clk_rvr_id=322156448459
www.xtremehobby.ashop.com.au/p/1213342/l...or830kv-12s-edf.html
of interest, but not relevent - www.rcgroups.com/forums/showthread.php?t=1426004
