The Café (There is no Topic)
16 Nov 2025 09:04 #17821 by Klipkopwildlife
As a teenager they had a couple of Dragon Rapides at Hurn airport doing the Channel Island run. I have a plan and hope to build one one day. I was devastated when later my boss, Corky Hoare, and I had to go to the Islands to work, we had to take a van with us and thus flew in a Bristol Freighter.
17 Nov 2025 16:51 #17822 by THE BLACKBIRD
Iv put the old heater back in position and it fires up but i have no control only on and off as the control panel is blank, it runs for so long then stops on its own
The new one the problem is the igniter plug not working, how the hell you get at that iv no idea as it all seems sealed in
At least i can heat the shed while i fix the new one, no point in contacting the makers/ sellers as its from China
18 Nov 2025 11:45 #17823 by THE BLACKBIRD
So at 3-30 am this morning i ordered a new igniter plug for the heater, the pump is working ok as the 1/8th o/d fuel pipe came apart and it was squirting spurts of diesel on the floor
19 Nov 2025 15:12 #17824 by Eric
Believe it or not - today, Weds 19th is International Men's day  - - but it is also International have a bad day day!
19 Nov 2025 15:37 #17825 by Eric
It is snowing in places in the UK today.
If anyone wants to make a Keir Starmer snowman,  it's easy.
Make two spherical shapes, place them side by side, then put a cylindrical shape with a round end on top of them!
  • Flytilbroke's Avatar
20 Nov 2025 09:57 #17826 by Flytilbroke
I haven't s clue what this is, and don't really want to know either.
Weds 19th is International Men's day.
20 Nov 2025 10:11 #17827 by Flytilbroke
I would start a thread or whatever about age related memory loss. But, I would forget I had done it. Much like when I make a cup of tea, it gets cold, so I microwave it but it gets cold in the microwave. Better make a coffee instead as I take that right away. Damn, I forgot I put the kettle on, it's coldish now too so gotta re-heat it as well. Do you know that when you put coffee powder in the cup while waiting for the kettle to boil then add a tea bag before pouring the water in,,,, it tastes funny?? So, start again.. Hmmf.
20 Nov 2025 10:40 #17828 by Klipkopwildlife
Damn, so that's what's wrong with me!
Thanks: Eric, THE BLACKBIRD
20 Nov 2025 19:52 #17829 by Eric
21 Nov 2025 06:58 #17830 by THE BLACKBIRD
Another sleepless night, so i went into the freezing shed, there was ice on the outside of the door, i switched on the old heater and it started straight away and was warming the shed
So i had the new igniter plug and i fit it in the new heater and put it all back together, then fired it up
Only for the number 10 to come up on the digital panel telling me that the igniter is faulty
My luck never changes
I have a feeling the plane a 787 will crash on the way to South Africa   my bad luck will end then
21 Nov 2025 07:30 #17831 by Eric
Minus 4C this morning, at 7am. Guest-cat was sitting in the porch, via the hedgehog hole - waiting to come in!
21 Nov 2025 09:49 #17832 by Klipkopwildlife
A wiring problem then Tony?
27 Nov 2025 10:01 #17833 by Flytilbroke
Home heating is so expensive, especially if living in the many areas who have received no piped gas supply and so never had the benefit from the gas the UK used to have.  So, to help my comfort and reduce the cost of heating in my home I only use enough heat to take some chill off areas where it is little used and to keep damp away. I also keep the living room a little warmer in the low sixties Fahrenheit.
 What I do when needed, I use an electric over-blanket on my bed under the Duvet, and an electric heat pad on the chair I mainly use in  the living room. This has greatly reduced the overall cost of me staying warm as the Basic heating is set at a fairly low setting.
28 Nov 2025 20:48 #17834 by Eric
Solar flares can corrupt Airbus electronics! -
airlive.net/news/2025/11/28/breaking-mul...XNPJHtiJXSMmPbUs0lCQ
30 Nov 2025 08:30 - 30 Nov 2025 08:47 #17835 by Eric
Just how reliable are lithium batteries?
This article is from an electric car forum, but the same thing - albeit smaller - applies to our e-flight batteries. -
  · Media hype around “Made in China” battery systems being the “best” has never been confirmed in real-world practice.
We are raising serious concerns about Tesla Model 3/Y LG NCM811 battery packs (LGES Nanjing), which show extremely high failure rates and a noticeably shorter end-of-life compared with Panasonic NCA packs (Made in USA).In over 90% of the cases we receive, cell-level repair is not possible on LG packs. The cell degradation within affected modules is far beyond anything that could be restored. The issue is rarely a single bad cell—most failing modules contain multiple cells with extremely high internal resistance. Out of 46 cells, it is common to find 15 cells over 100 mΩ ACIR, and the remaining 30 cells above 50 mΩ ACIR.
Given these patterns, adjacent series groups measured in parallel modules often show resistance values already above acceptable limits. This means that even if we replace the faulty cells with used, matching donor cells (never with new cells), the remaining weakened cells are likely to fail in a cascade. This makes the repair operationally unsustainable, as the entire pack is clearly nearing end-of-life, exposing us to extremely high warranty and labor costs.
Another unknown is this: If one out of four modules is badly degraded, what are the chances that replacing a single module will result in a stable pack, and for how long? Is it realistic to expect another 100,000 km of trouble-free use after replacing one module? Most likely not.
At this moment, during ongoing experimental testing with real customers experiencing LG failures, we are losing over €20,000 per month in operational time while investigating whether LG’s Chinese NCM811 systems can be sustainably repaired. At this stage, we can confidently say: the cells are, to put it mildly, catastrophic. Panasonic has mostly single cell falire at 250,000km, and it is repairable, where LG has multiple cell failure. For reference:• A healthy Panasonic cell typically shows ~10 mΩ, while a new LG Nanjing cell starts around 28 mΩ.• A failing Panasonic cell reaches ~28 mΩ, which is what LG cells measure when brand new. It is extremely difficult to explain this complexity to customers.The only alternative we can responsibly offer—although very rarely—is replacing the entire battery pack with a used Panasonic pack from the secondary market.
This brings us to a fundamental question: Where does the media hype come from claiming that Chinese-made cells are “better”? In practice, the best Li-ion cells are made in Europe (LG Chem, Samsung SDI) and the USA (Panasonic).China’s strength is limited primarily to LFP technology, but Blade-format LFP packs are entirely non-repairable researched by independent institutes.
⸻Important Notice for Tesla owners with Chinese LG packs - Due to extremely high operational losses (20,000€ per month on LG packs), we must introduce an experimental “repair check feasibility” fee to determine whether repair is even possible. If the pack is deemed non-repairable, the only options are: 1. Replacement with a used Panasonic pack. 2. Full pack replacement at a Tesla Service Center.
When supplying used Panasonic packs, we do not guarantee range, charging speed, or long-term capacity. Warranty covers functional defects—not degradation or reduced range.This article also serves as an official disclaimer.
⸻Reference DataPart number: 17000012-00-BOEM price: €15,355 (excl. tax, EPC)
EVC repair check: €1,200 non-refundable (remove/assemble) Waived if repair is possible.
EVC full repair: €5,500 (excl. tax).
EVC Panasonic swap: €8,000 (excl. tax).
⸻Estimated End-of-Life (EOL)• Panasonic packs: ~400,000 km• LG NCM811 (China): ~250,000 km
Last edit: 30 Nov 2025 08:47 by Eric. Reason: Correcting copy/paste corruption to the text!
Time to create page: 1.634 seconds
