The Cyprus A10 THUNDERBOLT
02 Dec 2012 00:44 #106 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Re: The Cyprus A10 THUNDERBOLT
Been lord of the rings today, started the rear moulding,
Started with a load of balsa
Then cut out eight rings, seven at 3/4" thick and one 1/2"
Stuck them all together on the nacelle and began sanding
Im going to make a plug from it and TRY to make a mould and then attempt to do it in fibre glass :unsure: :unsure:
Thanks: The Beard, Sarah-Jane Smith
02 Dec 2012 00:54 #107 by The Beard
Replied by The Beard on topic Re: The Cyprus A10 THUNDERBOLT
Very impressive work BB good to follow a build like this one,out of the ordinary and loads of tips being picked up.You and Tony together are very educational.Idela place to learn to build models from scratch.It shows that even in these larger builds the techniques are the same.
02 Dec 2012 00:57 #108 by Ex-Member
Replied by Ex-Member on topic Re: The Cyprus A10 THUNDERBOLT
i am loving the look of this one BB.
lots of interesting new ideas for me to play with.
02 Dec 2012 01:32 #109 by old fart
Replied by old fart on topic Re: The Cyprus A10 THUNDERBOLT
Watching with interest. :)
02 Dec 2012 04:45 #110 by Eric
Replied by Eric on topic Re: The Cyprus A10 THUNDERBOLT
Biggest tin - catering size can of beans or coffee. Or if you know a printer, try and separate him from a sheet of lithoplate.
02 Dec 2012 07:09 #111 by Phil Wood
Replied by Phil Wood on topic Re: The Cyprus A10 THUNDERBOLT
I see from this post that you've found out what I said about this orange foam being easy to sand to shape.
www.modelchat.org.uk/forum/scale-models/...it=20&start=80#29355
It should be available in Cyprus, it's used here as a building material, I think it's underfloor insulation.
It's technical name is "Extruded Polystyrene"
It forms a great material when covered in Poly C (Floor Varnish) & baby wipes. :lol:
Seriously, baby wipes,..... they are similar to tissue but will form around complex curves & are ridiculously strong.
I cut a thin sheet of the stuff & tested it .... great results. ;)
02 Feb 2013 23:03 #112 by THE BLACKBIRD
Im also hopeing to get the A10 build going again wanted it flying this summer but i dout it now :(
06 Aug 2015 08:07 #113 by THE BLACKBIRD
Im looking to start on this build again when i get back m the Nats if my plans work out,
Still looking at this aileron / air brake thing, and still cannot see it in my mind,
Thinking im going to need three hinge lines, top and bottom for the brake and a middle hinge for the aileron, one sevo for the brake and one for the aileron, the one for the brake will need to be moving with the aileron, but there is not room to fit it in the aileron ???
Just cannot get my head round it :silly: :S
06 Aug 2015 08:23 #114 by Ex-Member
Replied by Ex-Member on topic The Cyprus A10 THUNDERBOLT
two servo's for the aileron, one on top of the wing and one underneath. separate leads to the rx.
then program a mix that alows you to use them together for aileron and separately for brake.
maybe?
06 Aug 2015 10:50 - 06 Aug 2015 10:54 #115 by Eric
Like this??
[IMG
Last edit: 06 Aug 2015 10:54 by Eric. Reason: link didn't attach
Thanks: Klipkopwildlife, THE BLACKBIRD, old fart
06 Aug 2015 12:27 - 06 Aug 2015 12:30 #116 by THE BLACKBIRD
This is my thinking on the aileron / brake issue
As i dont want pushrods above the wing, the problem is the brake pushrods / servo really needs the be part of the aileron ( but there is not room ) to keep the brake pushrods the same geometry when the aileron moves,
I think ???? :unsure: :dry: :S
Last edit: 06 Aug 2015 12:30 by THE BLACKBIRD.
06 Aug 2015 15:03 #117 by Ex-Member
two servo's inside the wing as mentioned above with offset horns, so the horns sit side by side inside the aileron.
06 Aug 2015 15:54 - 06 Aug 2015 15:55 #118 by THE BLACKBIRD
It will defo need three hinge points top and bottom for the brake and one in the middle for the aileron
Last edit: 06 Aug 2015 15:55 by THE BLACKBIRD.
07 Aug 2015 16:40 #119 by THE BLACKBIRD
Thought I would do a bit of modelling today, been a long time since I cut any balsa,
So I had a play with the aileron brake,
Made a scale wing tip from the plan and started the aileron
Hinged it at three points, this shows down aileron
This up aileron
This brake deployed
This up aileron with brake deployed
And down aileron with brake deployed
Just the matter of connecting the servos now :S
Thanks: Klipkopwildlife, Ex-Member, Quorneng, blue123, old fart, Ralpharr2001
27 Aug 2015 11:53 #120 by THE BLACKBIRD
I think I have a deal with Demetri with the SU27 in a swap for a new JetCat 100RX I stand to loose a lot on it but its the best I can do,
I have a quote for the repairs to my turbine for the last crash of £500 so I will get that done, it is a lot of money but when I considered that a service for a turbine runs at 300 + it makes it sound better.as it will come back as a new engine
So that means ill have the turbines for the A10.
And it will mean more to me to get the A10 to fly than to fly the SU27
So it looks like the A10 is back on the board when I get home
Im still trying to find A3 size sheets of acetate for the canopy, Andy has kindly offered me one but I think I will need more than one to master the art of canopy making
Just bought a 1/48 scale plastic model of the A10 to use as a guide. as the wings have some serious under camber on them
Time to create page: 1.412 seconds
