- Thank you received: 1420
The Cyprus A10 THUNDERBOLT
- boz
As OT said think again, if you can't find an alternative solution, then use them.
If you don't you will always be wishing you had.
Having said that Ralph is right also, but it's not the choice you wanted, boz.
- Thank you received: 10842
Anyroods I pressed on ripped the hatch off
And binned it then started to make and fit a new one using the hinges I had because I had worked out how to do it
Only when I had done it IT WOULD NOT OPEN
Sooooo version 3!!!! using the new hatch and with a bit of hacking and cursing, could not get the other apart so finished up with damage, but it will repair, and I cannot afford to waste any more of this ply as I only have enough for the other hatch and will not buy more @ 56 quid a 1200 + 600 sheet +carriage
Using a tube I have it working
And I managed to slice open 3 finger and a thumb all in one go :S
Just not safe to be out of bed at the moment :whistle:
www.google.co.uk/webhp?sourceid=chrome-i...-8#q=0.4mm+plywood&*
Even smaller sizes might help but there is a selection of sizes and prices
and here www.google.co.uk/webhp?sourceid=chrome-i...m+plywood+600x1200&*
- boz
I was wondering if some of the obviously very talented metal workers, turners, (lathes) machinests, " I know"spelt wrong, could get together in a thread, and try and come up with something hand made, ie like for instance this hinge thingy that OT, was describing to BB,.
this is just an example, but what a benifit it would be to very serious builders, getting together to solve what appears to be ( just a hinge) that the design could be improved to suit not only BB,s problem, but hinge problems that builders must be having everywhere.
You all know I'm a novice on here re modeling, but piano hinges, and other diy home type hinges, are not really designed for models.
I'm ready for the "flack" lol,
Could be moved to another thread if spoiling BB,s build thread, "dare I say" fire away.
Klippy has the same problem, getting items to South Africa.
- boz
I was using the hinge as an example, and OT,s description posted earlier, as an example,
Sorry if the post was not descriptive enough.
Instead of using parts usually made for home use, hope this helps, boz please move if spoiling thread. Boz.
I brought that order when I was in the UK last September back with me on the plane, but it cost nearly as much, the only difference was my son paid for it
Thing was it was delivered F.O.C to me in the Wirral from slec
Boz you don't detract from my threads, that was a good idea you had
- boz
Rods across hatches into formers with brass arms to lift as they open keeping edges sharp/Wish I could draw on here to show you. Use washers as bearing surfaces Experiment with a dummy
Would a tread on designing parts (not available) retail be of help? Just a thought, boz.
And here is the finished hatch all working, with todays blood on it, they say they fly ok if they have blood on them, this should be a cracker with all of it I have shed on this one :lol: I bushed the brass tube where it hinges and I fitted two powerful magnets to keep it close,, ill work something out to open it later
Tonight I started on the other one hopefully this one will go a bit quicker
At the third attempt I did the fairing between the fuselage and engine housing
Cut the plugs off the housing and glassed them
