The Cyprus A10 THUNDERBOLT
Are you building this one from a plan BB, or designing it yourself. If it's the latter, I'd consider changing the section to something a bit more friendly at model aircraft speeds. A supercritical section may not work effectively at the Reynolds Numbers we fly at.
- Thank you received: 10842
Had to redo the fairing between the engine pod and the fuselage as the resin never hardened
I need a canon on the front, thought about what I could make it from, so decided to do it in fibre glass
So got some chemi wood and started carving
I drilled indents where the holes will go, put some black paint in them so they would show up
Gave the plugs and coat of resin
you have certainly got the building bug again Tony.
Then I gave them a few coats of paint, more filling and sanding to follow
I drew and cut out a full set of 28 ribs, still some work to do on them yet
keep up the good work
