HEINKEL HE 111
but i can't not build,so i have ignored everything else i have to finish and started something else for a change of scenery.
needed a change from the Lancaster so i started building the fuselage for my 100inch wingspan Heinkel.
Formers all cut out and mounted to the jig, stringers all on.
As with the Lancaster, the nose is removable for storage purposes, so it is built separate to the main fuselage.
The nose is all glazed and as the glazing is non symmetrical i have been cutting the formers and test fitting.
i will go back to slobbing off now. [badass]
do i make the V1 that it carries and drops off in flight or not.
and do i make the V1 edf or just a glider.
Nice former & stringer fuselage.
Is it going to be skinned?
if i feel like doing some i do and if not, i don't.
the other stuff, i HAVE to put in "X" hours a day or else.
- Thank you received: 10842
