HEINKEL HE 111
robarts fitted.
hidden control arm made and fitted.
rudder snake fitted inside the fuselage, i takes a 1m snake to get anywhere near the front.
so i am now sealing the fin and rudder, then i will cover them ready for fitting.
- Thank you received: 10842
I do like this build, very unusual
the snake is supported every 6 inches down the fuselage.
worse come to the worst, i will have to fit a horn to the outside and re-rout the snake.
its how they did it on the plan, so once the fin and rudder are fixed in place i will sort out the servo tray and try it.
anyway, been painting.
painting it off the fuselage because getting straight lines would be near nigh impossible once it is glued in place.
i know the swastika is sensitive to some people, but if i can do a Lancaster, zero or mustang with full markings i do not see why i can not do the same with the heinkel.
No malice is intended, it is just a model.
But i will not post anymore pictures of this stage of the painting and if the mods feel the need to delete this post. then that is fine and i understand.
And you have a steadier hand with the paintbrush than me
might be an idea.................................................
just waiting for the paint to dry and i can put the reg number on both sides.
then we can move onto the next stage............................................
ran the elevator snake through the fuselage and tested that.
