the fuselage is now planked up to the wing mounting point.
need to sand it down next and then look at the wing center section. eeeeeeeeeeeeeeeeeeeeeeep.
on the original the 100" wing is one piece and bolts in to the fuselage.
i want to have the center section on my wing fixed permanently to the fuselage to keep most of the wiring set. only have to connect the ailerons each time then.
so some head scratching will be in order.
so the next job is to sit down and cut some huge wing ribs. (might get 3 out of a sheet of balsa)
