TSR2 in depron
20 Sep 2014 19:21 #76 by Eric
Replied by Eric on topic TSR2 in depron
I don't lend my face to anybody, never mind Smi Ling! :P Who is he/she, anyway? :woohoo: :evil:
21 Sep 2014 09:20 #77 by alan cantwell
Replied by alan cantwell on topic TSR2 in depron
Tell you what, its a BIGGUN! Most impressive, But will it be a flier?
21 Sep 2014 09:40 #78 by Ex-Member
Replied by Ex-Member on topic TSR2 in depron
only time will tell Alan, only time will tell. :)
21 Sep 2014 17:17 #79 by Ex-Member
Here's a 'weight reduction' suggestion Tony - have you considered making it dolly launched? That way you could dispense with the retracts for the first few flights and the model would be cheaper as well as lighter.
Jaqui says: "Oooooooo what a whopper!!" by the way! ;-)
21 Sep 2014 17:40 #80 by Ex-Member
dolly launch might be an idea or even a bungee ramp.
anyway.
today i have done a little bit more sheeting to hold the arse end straigh so i could glue the tailplanes on.
ok i need to run some glue along the edges yet, but the ali spars are glued in place and they are level and square.
need the servo's and esc next before i can do much more, so i think i will play with the avionic bays a bit.
22 Sep 2014 12:20 #81 by Ex-Member
having a play.
need to add the lower bits, sort the hinges, paint add wires and braces.
22 Sep 2014 17:09 #82 by Ex-Member
bit further on.
other side to do yet. :unsure:
24 Sep 2014 20:42 #83 by Ex-Member
not much to report as the shed base has taken priority for the last two days.
i did get a couple of bits of depron glued on this morning as it was raining, but that's all.
25 Sep 2014 19:12 #84 by Ex-Member
right i had some time to myself today so i got a little bit more done.
made up the ailerons and hinged them to the wing.
the original only had flaps on the main wing as it used tailerons where the whole tailplane could be moved either as elevators and as ailerons at the same time, overly complicated for me i thought. :P
did a little bit more sheeting where i can, need the servo's before i can do any more.
fitted the rudder torque rod as well.
want to look at the u/c mounts tomorrow if i get the time.
26 Sep 2014 21:01 #85 by Ex-Member
no pictures today.
i have sorted the fuselage round the wing mount a bit more and started the wing to rear fuselage fairing.
that's about it.
ordered all the bits needed to wire it up, so as soon as they turn up i can crack on and finish it off.
30 Sep 2014 20:05 #86 by Ex-Member
parts turned up monday, but so did my sons new shed.
so nothing has been done to the poor girl.
hope to get something done thursday.
i need to finish this one for display at the fly in. :P :P :P
01 Oct 2014 13:17 #87 by Quorneng
Replied by Quorneng on topic TSR2 in depron
Tony
'Display at the fly-in' - Any chance that would that be a flying display?
01 Oct 2014 13:33 #88 by Ex-Member
you never know.
though a tarmac runway might be better for it.
01 Oct 2014 17:36 #89 by Quorneng
Now if you could duplicate the originals tandem wheel UC....... :P :P :P
01 Oct 2014 19:20 #90 by Ex-Member
i am working on it, got the wheels today.
covered the top of the main wing.
looked at the front u/c.
need to work out how to steer it next.
Time to create page: 1.127 seconds
