Trent Meteor for 2015 start.
not sorted wash out yet.
yes i hope it will be strong enough once built, but i have all the spars and wing tubes to sort as well.
Is that the full thickness of the wing or just 1/2?
the bottom will go on later.
i do it this way so i can make sure it is all level before i do the underside.
not glued in yet as i am just working out the shape.
the motors sit very high in the nacelle, so i will have to design a ply mounting system to take them.
plus side is that there will be plenty of space under the motors to take the esc's and give them some nice cooling air flow.
once i am happy with the shape, i intend to plank the whole thing and have a removable front section over the motor.
cut the elevators off and fitted the hinge block as well.
then i made up the cores for the additional fins.
The i cut lots of holes and tomorrow i hope to get the ribs and spars fitted to the underside.
then i can sheet the top and work on the elevators.
- martynk
- Premium Member
Martyn
got all the spars and ribs fitted to the underside.
sheeted the auxiliary fins with balsa and sorted some spars in them.
sheeted the top of the tailplane.
need to shape the fins still, then start on the huge elevators. only then can i sort the servo mounts and sheet the underside.
