- Thank you received: 1476
- Ralpharr2001
My father was HMAS Sydney during the Korean war and worked on the Firefly. Hence my interest in this subject. I did start this model a number of years ago but had two house moves since then and what I had built has got damaged/lost/deformed. So i'm going to start afresh. It is an 81" wingspan model. I am going to install electric power rather than an oil burner.
Sadly Vance has passed away so the the plans, laser kits and parts have been taken over by Chuck Greaves. Chuck was very helpful getting my order sorted and shipped. I sent away for the plans, build instructions and the laser cut parts which arrived from the USA 2 weeks from order.The plans are on 4 sheets, very informative and detailed. Laser cut pack is very good with just a few laser burn marks. Nothing a wipe over with sandpaper won't sort.
Assembled to bottom of the fuselage over the weekend. The design is a centre (1/4" sq balsa) crutch onto which the lower and upper formers are added. Then the fuselage sheeted with 1/16" balsa.
Retracts are on order. Vance has a specially designed set of air operated retracts but I prefer electric servoless type so have sourced them elswhere. I've yet to sort motor and servos.
- Mike Rolls
- Thank you received: 573
should be a beauty when she is finished.
look forward to following your build thread.
- Fly-Navy
- Thank you received: 295
- Squirrelnet
- Thank you received: 2067
Looking forward to seeing this one develop
- Ralpharr2001
Fly-Navy wrote: Now your talking Ralph, been waiting a long time for this one to arrive in one of your builds. Beautiful looking a/c and not modelled enough in my opinion. Eagerly awaiting further posts, are you sure we cannot tempt you to install a noisy smelly thing?????????
Definitely not!!
- Fly-Navy
Well I was a fly boy matelot, my excuse anyway
- boz
- Thank you received: 1420
- Ralpharr2001
These servoless retracts are rated for 8 - 10kg models so just the ticket as the model is going to be approx 16lb. The action is very smooth. The oleo's were separate to the retract units and slightly longer than required. So I put them in the lathe tonight to get the pivot to axle length correct. Took 20 minutes but they are spot on to the plan. They will need a bit of dressing up to get the scale look but a great starting point. If ever there was an incentive to build a wing these are it.
Not working tomorrow so I can crack on with the build. My sheet balsa order has arrived from Balsa Cabin so I have everything I need to complete the air frame. Only a few things left to buy, motor and ESC and I'm not decided whether to go Hacker or something else. The sound system has been sourced and I will get that at the end of the month.
now where are the build pictures.
- Squirrelnet
- boz
- Ralpharr2001
Got on well today. The bottom section of the fuse is pretty well built, just sheeting to do. As you can see the laser cut parts go together very well. Remember, the photos show the bottom half of the fuselage as first it is built upside down. When all the sheeting is done I will turn it over and build the top onto this bottom section.
As expected I have already deviated from the design!!
This is a picture of the full size. You can see what i'm trying to replicate.
- Ralpharr2001
First step was to make the arms by flattening each end, drilling holes for the pivot pins and cutting the hook. The whole assembly was then silver soldered together.
Then I added some thin brass sheet to form the inner and out flange which was soft soldered into place.
A little bit of shaping and we have a hook that is close the scale that i'm happy with. Compare it with the picture in the previous post of the real thing. I will add the internal bracing angles with a soldering iron later. With some filling, sanding and painting it will look quite good.
