- Thank you received: 10722
- crash happy
- Thank you received: 1203
- Ralpharr2001
- Thank you received: 1476
- Ralpharr2001
I gently heated up the glass sheet and pushed it into the wing and fuse which helped it adopt the form. Did this several times until the glass sheet took the correct form, trimmed it with a pair of scissors. Repeated for the other side, then glued them into place with resin and bulking agent to make a paste. I still had to use some pins to hold the shape. Waiting for it to all dry and see how it turns out.
- crash happy
- Ralpharr2001
Started tidying up the section between the wing fillets on the fuselage. I cant seem to find a decent picture of the full size to get an accurate understanding of how the fuse is faired into the wing fillets. You would think some one would have thought "i'll take a picture of the fuselage fairing into the wing so that it will help Ralph when he comes to build his model". Bloody photographers, so inconsiderate!!
Also had another bash at the flap system. Still not happy with it. So decided to reprogramme the servos. I'm using Hitec HS-5625 MG servos on the flaps and have the ability to be programmed, using a dongle on a laptop, for throw, speed, centre position, sensitivity and a few other bits.
At 6V they give 9.4kg.cm. I need about 28mm total throw and 180 degree of arm travel. So by my calcs at half throw (when the arm is at 90 degrees to servo, so maximum load, lever is 1.4cm) I will get 7kg. I think that should be enough. If my calcs are wrong let me know. So at each end of the travel I should get more than 9.4kg to pull the flap closed or hold fully open.
With 7 kg on each flap servo you would likely be able to raise the plane off the ground by simply extending the flaps.
It am pretty sure the full size couldn't do that.
- Ralpharr2001
There you go Eric never had a problem with all my Savox servos,
- Ralpharr2001
So, located the cowl onto the fuse, lined it all up, clamped it into place, easier said then done, and drilled two holes through the front former into the former that is glued to the cowl. Fitted a couple of 4mm T nuts to the cowl former and hey presto the cowl is secured at the back.
For the front I cut some tabs 2mm fibre glass sheet and tacked them onto the cowl and drilled through into the engine mount back plate. A wipe with Hysol epoxy and they are installed. Access to these fixings is by taking the spinner off. So the back and front of the cowl is fixed. I think it is a bit OTT but better safe than sorry. A bit of a pain to remove but as I said earlier hopefully i wont have to do it often.
So to get a nice tight fitting between the cowl and the fuselage I put some packing tape on the fuselage where the cowl touched and coated it with release agent. Mixed up some filler and applied it to the cowl former and pulled the cowl onto the fuselage with the bolts. removed the excess filler and let it dray before trying to separate it from the fuselage. Should give a nice tight thin join line.
- Ralpharr2001
Nice to make some good progress.
