- Thank you received: 1476
- Ralpharr2001
Anyway, i'm back on it again. The Firefly has not progressed much in the last two years. I'll post what i've done soon.
Not much has changed since your last visit!
- Thank you received: 10722
- Ralpharr2001
Doors open
doors closed
Had a bit of fun designing and printing the inner frame to replicate the full size. It also adds a lot of strength the the fiberglass door. The black clips are printed from ABS - carbon filled filament. They will be screwed to the oleo legs.
Gear door attachment and detail
- Ralpharr2001
Still got a lot of work to do on the cowl before painting, but getting there slowly .
- Ralpharr2001
- Ralpharr2001
Next problem was instruments. I tried to copy images from the web and reduce them down to size using a piece of illustrator software. That didnt work so gave up with that idea. Searching through my 'must keep that as it may come in useful in the future box' (a big box!) I found a decal sheet for instruments at 1:5 scale. How lucky was that! So copied them and reduced down to 1:6 scale, printed 3 of them on photo paper and they came out OK. Definition and colour is good enough to use.
Placing the instrument panel over the printed sheet the dial size on the 3D print is slightly too small. So will adjust and reprint. Hopefully this will work.
- Ralpharr2001
- Janine
- Senior Member
- Janine
- Thank you received: 121
- Ralpharr2001
A month or two ago I wanted to sort the canopy installation but found that the vac forms I had were scratched whilst sitting around the workshop. My own fault, ham fisted! So contacted Bob at Heritage Wings RC, who has taken over the Vanguard plans and kit business after Vance Mosher passed a few years ago, and ordered a new set of canopy vac forms. Bob was still in the process of getting all the bits together so was dealing with each order as it came in. He had to reinstate his vac former and clean up the plugs. This took a month or two. Parcel arrived today from Bob with two sets of each canopy (I only ordered one set) and a spare set of wing tank forms as a gift. A real pleasant surprise and has given me a bit of a boost.
So this morning I flatted off the wings with 800 wet and dry and put fine putty into any marks. The plan is to get the airframe in paint by the end of August. The wing is leaning against my rotten fence panel (another job that needs doing) to give an idea of how big this plane is.
