Boomerang Sprint
- Inactivated User
- Thank you received: 14191
- Si_B
- Thank you received: 680
Been having a think about the layout of all my gear. Will post a picture of just some of the stuff which needs to go in. Still need to think about the gas and fuel valve, pump, shut off valve, retract valve etc etc etc.
Simon
- Si_B
- Si_B
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
- Si_B
Started to plumb the airlines back in, then realised there was no fuel proofing inside the fuselage, so stopped, pulled out what I had done and fuel proofed everything in case there is ever a leak.
Will get some photo's tomorrow once some of the airlines have gone back in. All my bits arrived today and I was shocked at how little £100 gets you when fitting out a jet. Three of four bits of pipe, a couple of quick connects and some festo fittings and that's about it!!
Getting there slowly, but enjoying it.
Simon
it will be well worth it in the end though.
- Si_B
Went with a mate to watch him go for his B at the weekend up at Wroughton. Beautiful site, such a shame they are losing it and someone is going to to cover the whole lot in solar panels. Such a big space, shame there never seems to be any compromise between the developers and a flying club that has been there for 50 odd years I think?
Anyway, the jet guys turned up in the afternoon and it was great fun having a good look over their installs and watching them blast about.
Simon
- kamco kid
- has anyone found my marbles?
and yes, it's very sad that yet another perfect flying venue is being swallowed up in the name of progress
Rich
- Si_B
- Si_B
Got the steering wires back in and the front airlines tucked nicely away.
Still waiting for the longer servo extensions to arrive, but got a few braided and secured in the wing (seemed rude not to start connecting up to the rx as it's not in the way). Air cylinders back in and the electronic valve mounted out of the way underneath as I will not need access to this once tested (hopefully!!)
That's about it for today, need to get on with some work.
Simon
Don't bank on it! The bit you can't get at is the bit that always goes wrong!
If your nose-leg is the same as the ones I've seen on boomerangs, the plastic block that the steering pivots on is a failure point if you get a 'firm' landing. I've seen a couple sheer off for no apparent reason.
- Si_B
Not sure what plastic block you are referring to?
Cheers,
Simon
