- Thank you received: 680
Boomerang Sprint
- Si_B
Got 5 flights in on my Intro, so happy to start my jet flying for 2014. Got the last flight of the day as a lot of people had left, pretty amazing flying against a black sky as another storm approached. Also the only flight when I could actually hear my engine.
Got another jet meet on the 11th, so hopefully warmer weather for the maiden.
Cheers,
Simon
- RobC
- Thank you received: 215
- Si_B
Cheers,
Simon
- RobC
- Si_B
- RobC
- Si_B
- Thank you received: 10615
- Si_B
Was going to go flying but the weather has been miserable this morning, so thought I'd fire her up in the garden just to check everything. Glad I did as it doesn't work. My second new turbine which seems to be faulty out of the box.
Sent an email to Wren, so will be waiting to hear their response, but I'm guessing already it will have to go back, just like my Jetcat 90rxi which was faulty out of the box.
Only bright side to this is I did not waste time on a 60 mile round trip
Regards,
Simon
If the pump is stuck, it can be freed by standing it in a shallow bowl of fuel (about 8mm deep) and then repeatedly swapping the battery connections, a bit like rocking a car to disengage a stuck starter motor.
You dont seem to have much luck with you turbines Simon
- Si_B
Might run the pump just to be sure, but it primed all the lines okay so I don't think that is the problem. Might be a incorrect parameter somewhere, I'm sure the guys at Wren will sort me out.
Simon
- Si_B
Simon
- Si_B
Could be a faulty rpm sensor or ecu so playing it safe and sending it back to Wren for a check over.
Will post back soon.
Simon
