× For those of you with deep enough pockets
Boomerang Sprint
23 Jan 2015 19:20 #76 by Garry Pollard
Replied by Garry Pollard on topic Boomerang Sprint
Good news Simon, lets hope the prob will be solved.
  • Si_B
  • Si_B's Avatar Topic Author
24 Jan 2015 09:40 #77 by Si_B
Replied by Si_B on topic Boomerang Sprint
Not trying to get too excited, but I might have found the problem. After thinking through what Mike from Wren turbines said, "can't see how a turbine can have three good runs at the factory and then not work", my thoughts went back to the servo connector on the end of the rpm sensor.
I braid my servo lines so nothing can rub, and when I took the servo connector off I thought it was a bit suspect. As this is the easiest thing to change (the other option is the rpm sensor or the xicoy ecu has gone bad in the box??) I got up the morning, dived into the shed and changed the servo plug. Guess what...........I have an rpm reading. This was the reason why the turbine would not initiate a run.
Waiting patiently till 10:30am, which I think is acceptable to make some noise.
Simon
24 Jan 2015 09:53 #78 by Ex-Member
Replied by Ex-Member on topic Boomerang Sprint
Thats good news Simon.
Lets hope that the problem is now solved.
  • Si_B
24 Jan 2015 11:07 #79 by Si_B
She runs :woohoo:
Took a bit of effort as I think the pump is still a bit stiff from being stored so long. Best thing to sort that is to get some fuel through it...........which is what I'm going to do this afternoon.
Will post back later.
Simon
Thanks: Ex-Member, THE BLACKBIRD
24 Jan 2015 13:47 #80 by Garry Pollard
Thats saved a bob or two Simon, well spotted
  • Si_B
24 Jan 2015 15:20 #81 by Si_B
To be fair, I would not have spotted it if I hadn't talked to the boss at Wren. You learn something everyday, so will be something to check in future installs.
Didn't get to fly today due to work and marking. Got an interview next week at a really nice school, so fingers crossed.
Going to try and have a few flights in the morning. Will get my little flycam on my hat to catch a few low passes.
Simon
  • Si_B
25 Jan 2015 16:50 #82 by Si_B
No photos, my little cam has died. Motor fired up perfect on both flights and was faultless. More than can be said for my second landing. Pulled up a bit short and caught a divot at the start of the strip where it is a bit bumpy. Looks like my only damage is a bent front steering pin but will check over next weekend.
Simon
  • Si_B
29 Jan 2015 23:10 - 29 Jan 2015 23:13 #83 by Si_B
There's the problem.
Couple of dents and scratches in the film, but no structural damage to the wood. Just need to source a replacement.
Simon
Last edit: 29 Jan 2015 23:13 by Si_B.
29 Jan 2015 23:14 #84 by Ex-Member
Will it not hammer straight.
shame though.
  • Si_B
29 Jan 2015 23:40 #85 by Si_B
Metal has torn where someone has put a very rough flat onto the shaft. Could bend back, but if it snaps on a landing it could cause a lot of damage. Think I'm going to play it safe and replace it.
30 Jan 2015 06:17 #86 by Ex-Member
Si_B wrote: Metal has torn where someone has put a very rough flat onto the shaft. Could bend back, but if it snaps on a landing it could cause a lot of damage. Think I'm going to play it safe and replace it.
Sounds like a good decision to me!
  • Si_B
15 Feb 2015 19:32 #87 by Si_B
Few problems with one leg not locking down, but seemed to have sorted itself by the third landing which was a greaser. Lost the light by that point but a great day. A rare treat to fly my turbine without any others in the sky.....you get to enjoy the sound to the full.
A great start to my half term break.
Simon
Thanks: Garry Pollard, Klipkopwildlife, Ex-Member, Quorneng, old fart
15 Feb 2015 22:46 #88 by Ex-Member
well done sir.
glad it all went well for you today. :)
  • Si_B
17 Feb 2015 18:21 #89 by Si_B
Treated myself to one of the Turnigy cams, so will stick it on my hat next time to see if I can catch some footage of her in the air.
Simon
17 Feb 2015 18:46 - 17 Feb 2015 18:48 #90 by Eric
Replied by Eric on topic Boomerang Sprint
You may find you get lots of footage of sky, and not much else. When I tried it, I found how much of the model flight I followed by moving my eyes, and not my head, so ended up making a 'gunsight' from a bike spoke, with a loop on the far end. After 'calibrating' it, if I keep the model in the loop, it is more or less in the centre of the lens field.
THEN you find out how hard it is to fly the model AND move your head to keep the thing aimed! :evil:
The beauty of digital recording is - it costs nothing to scrap hours of footage because it is rubbish! [badass]
You will also discover how rapidly the model disappears into the distance, so it looks as though you are filming a midge! :ohmy:
Have fun!
Last edit: 17 Feb 2015 18:48 by Eric. Reason: added a comment
Time to create page: 0.782 seconds
