- Thank you received: 680
Boomerang Sprint
- Si_B
To be fair, the gear installed in the model is pretty high spec, so once I've got it the way I want it, it should give me some good service.
- Jamie
- New Member
- Thank you received: 21
Si_B wrote: I eventually took everything out as I'm not happy with the way some things have been done. Going to take a while to get this back together, but I'm aiming for the 22nd March as this is the first jet meet of the year. Be good to take my old Intro and the new Sprint.
Simon
Simon,
The events for this year are coming together nicely www.jmajets.co.uk/events.php we have three at Long Marston.
Normally peeps come on here and say Hi and post in the introduce yourself thread before answering posts . Maybe you would like to do that please
Garry Pollard
- Si_B
Next issue was fitting the vac formed wheel wells. First one went in fine, then realised potentially why the original owner didn't bother fitting them as the second had not formed properly. Looks like it didn't pull down fully on the vac moulding so really big radii in the corners which don't fit the hole in the wing. Tried to ring Boomernag jets but didn't get a response. After thinking it through (and not wanting to spend anymore money as I doubt they would have a spare going for free in silver!!) I decided to modify the wing to accept the bad moulding. Will post a picture later, but I think once the wheel is in, you'd be hard pushed to notice (plus they are only there to keep rubbish and wet out of the wing structure). Got to remember that this is going to be my everyday flier !!
Was hoping to get this finished this week before going back to work, but things are no on hold till my retracts come back. Once they are in, I can test all the air lines, get her on her feet and then install the turbine and accessories.
Regards,
Simon
- Si_B
Might cut out the wood to modify the turbine rails tomorrow, but apart from that, there is not much else I can do till my wheels are back and my servo extensions arrive.
Cheers,
Simon
- Si_B
Cheers,
Simon
- Si_B
You can hold them in with self tappers, but I don't like this, so 3mm bolts with captive blind nuts at the back. Be rude not to have a quick test fit (excuse to get the turbine out of the packet yet again!!).
Seems a way off before this will be going in permanently
Simon
- Si_B
- Si_B
- Thank you received: 14191
- Si_B
Second one went in a lot easier for some reason.
Finally after what seems like a hundred times of flipping her upside down and then the right way up, she stands on her feet.
Now the fun starts. Got to test the air tomorrow for leaks, if that's okay it time to put in the tank and the turbine ancillaries.
Cheers,
Simon
- Si_B
Got the hopper tank in and the pump mounted with all the pipes safety wired. Still got pipe work to sort out in main tank, but need to run all the pipes and wires to the turbine first. I'm sure I will change my mind a few more times before I commit to fitting the solenoids, ECU and powerbox. Not short on space but it's hard to keep things neat and accessible.
Bought the Gemini 2 powerbox for redundancy on the rx batteries. Nice looking piece of kit, but I don't like the ribbon wire to the switch. It has little flexibility and is going to be a pain to hide the excess lead.
Cheers,
Simon
- Si_B
Getting on well with the plumbing.
Need more festo valves and the connectors on my solenoids don't fit the ecu. Silly little things just tripping me up now as well as wasted time waiting for things to arrive (and money wasted on postage).
Jet meet is on the 22nd, so time is running out. Was hoping to run the turbine this weekend, but that's not going to happen now.
Simon
