- Thank you received: 41
EDF Problems in SR71 Build.
- Walrus
- Premium Member
- Smile it makes people wonder what your up to
The smaller the number the heaver the wire. 8 gauge is thicker thn 10. Originaly wire was made by pulling it thru a die the more pulls the thinner the wire. The number reflected in Gauge refers to the number of pulls thru a die.THE BLACKBIRD wrote: I need to order some heavier wire for the SR i think the stuff i have put in there is not up to the job but the biggest can find is 10 gauge ??
How do you measure the wire
what is 10 gauge ? will it carry the sort of power im putting through it, keeping in mind that the lipo's will be about 15" from the esc's, from leasons already learned it is very high power.
Your thoughts gentlemen please
Or - have a google for a shop called Rocket Radio, or one called Truck King, here in the UK, they sell heavy cable by the metre.
There was a guy on EBAY selling the stuff, too, I'll see if I can find a link, a bit later.
- Thank you received: 10722
Wish i had known that before i parted with my £500 for the two.
Aparently they are known in the helli world as CASTLE CREMATIONS
But finding 8 gauge it is difficult, none here thats for sure .
- blue123
- Thank you received: 146
The test is to check if the wire gets unduly warm. If it does then its the 15" length that is the issue not the 12S.
You can always 'double up' wires rather than replace with bigger.
Ebay Item number: 230802939797
Loads of other stuff useful to us, too, from funny size nimh, led's, chargers, button cells for your calculator or watch etc. Have a look in his on-line shop.
- Grumpy42
