HobbyKing NEMESIS. Poly's bought an electric ARTF.
  • Phil Wood
  • Inactivated User
  • Inactivated User
04 Feb 2013 00:03 #16 by Phil Wood
Garry Pollard wrote: This is always a fault on ARTF Pol. I always beef this are up with hard wood triangular stock to really beef it up
That's exactly what I had in mind Garry .... Here's a pic of the U/C mounting holes .... the sheet of ply has captive nuts fitted and is only about one & a quarter inches wide.
If the U/C were to get a rearwards knock. such as hitting a stone or tuft of grass, it would try to rip the leading edge of the ply cross member out of the recess.
What is needed is triangular section to attach this cross member to the Fuz sides a lot more securely.
It may be a bit fiddly to get at, but I may even see if I can get a coat of GRP on the cross member itself.
This would have to be done from the inside & it's almost impossible to get at because the base of the battery hatch is in the way. (See pictures) .... It's not even practical to remove a piece of covering & glass it from underneath .... it would mean recovering the whole underside of the fuz.
Thanks: THE BLACKBIRD, Sarah-Jane Smith
  • Phil Wood
  • Inactivated User
  • Inactivated User
04 Feb 2013 00:16 - 04 Feb 2013 01:50 #17 by Phil Wood
I just thought that, while I'm making sure that my batteries are going to fit, I'll check if they'll fit my Super Strider as well .... here's the fuz of the two models together & the battery size is perfect .... I may as well maiden both of them on the same day & see if I bring them both home in one piece.
Last edit: 04 Feb 2013 01:50 by Phil Wood.
Thanks: Eric, THE BLACKBIRD, Sarah-Jane Smith
  • Phil Wood
  • Inactivated User
  • Inactivated User
04 Feb 2013 00:57 - 04 Feb 2013 01:50 #18 by Phil Wood
The next complaint we often hear about ARTF models is the lack of glue used in assembly.
I think they must use some form of hot glue, can anyone clarify this?
Look carefully at these pictures and you may just be able to make out some blue GUNK .... many of the joins show no signs of this so I'm taking no chances with this one.
I'm going to get a syringe with a long extension & trickle PVA wood glue along every seam .... it may add a few grams but a 5-6lb model won't notice it.
04 Feb 2013 01:16 #19 by Ex-Member
it looks very fragile pol.
04 Feb 2013 01:19 #20 by Garry Pollard
Replied by Garry Pollard on topic HobbyKing NEMESIS. Poly's bought an electric ARTF.
You are doing exactly what I do Pol. Every joint you can see. Doesnt take long, and adds very little to the model
  • Phil Wood
  • Inactivated User
  • Inactivated User
04 Feb 2013 01:52 #21 by Phil Wood
Cocked up there with the pic of the Strider .... posted the wrong pics .... just edited it.
04 Feb 2013 02:05 #22 by Eric
If the wing joiner is a carbon bar, do NOT tighten the locking screws! That will crush the bar, and next time you pull a bootful of G,- - SNAP! You'd be better with a pair of cuphooks and an elastic band.
  • Phil Wood
  • Inactivated User
  • Inactivated User
04 Feb 2013 02:11 - 04 Feb 2013 02:44 #23 by Phil Wood
Eric wrote: If the wing joiner is a carbon bar, do NOT tighten the locking screws! That will crush the bar, and next time you pull a bootful of G,- - SNAP! You'd be better with a pair of cuphooks and an elastic band.
It looks like aluminium Eric .... but feels very heavy, more like steel! :woohoo:
Last edit: 04 Feb 2013 02:44 by Phil Wood.
04 Feb 2013 02:15 #24 by Ex-Member
it is an aluminum joiner.
  • Sarah-Jane Smith's Avatar
04 Feb 2013 03:11 #25 by Sarah-Jane Smith
Replied by Sarah-Jane Smith on topic HobbyKing NEMESIS. Poly's bought an electric ARTF.
looks good! Have you finished yet? have you, have you? :P
  • Dean M
  • Dean M's Avatar
04 Feb 2013 13:42 #26 by Dean M
It does look very nice and like it will be very light. From looking at the pictures it looks good quality to
I nearly choked on my latte.
04 Feb 2013 15:22 #27 by Klipkopwildlife
Replied by Klipkopwildlife on topic HobbyKing NEMESIS. Poly's bought an electric ARTF.
Polyphilla wrote: The next complaint we often hear about ARTF models is the lack of glue used in assembly.
Can I suggest you thin the pva with some distilled water, it'll 'wick' in better.
04 Feb 2013 17:34 #28 by The Beard
Yes Pol the u/c came off with not much of a landing.Mine didnt like slowing down so the landing speed tended to be at the point where the model would bounce back up.The problem was it tended to bounce into a roll and cartwheel
  • Phil Wood
  • Inactivated User
  • Inactivated User
04 Feb 2013 20:30 - 04 Feb 2013 23:07 #29 by Phil Wood
willowlea wrote: looks good! Have you finished yet? have you, have you? :P
Oi gobby, are you going to come & have a blast at flying this beastie?
go on Sarah, it would be a great meet up!!!! [badass]
Last edit: 04 Feb 2013 23:07 by Klipkopwildlife.
04 Feb 2013 20:42 #30 by Eric
thin the pva with some distilled water, - - and a DROP of washing-up liquid - it breaks the surface tension of the water, and allows the mix to flow more readily.
Time to create page: 0.226 seconds
