- Thank you received: 10722
- Forum
- Forum Categories
- Reviews - Model Flying Shops, Products, Kits
- HobbyKing NEMESIS. Poly's bought an electric ARTF.
if you need to extend the fire wall just build a box the length you need to get the prop and spinner in the right place
Im doing the same on my Revolver
Logic says the case at the shaft end stays put, along with the black body, and the back silver bit spins with the shaft, because of where the wires are, but the screw-holes say the back end silver bit stays put, and the front silver bit spins with the shaft, because the gap between the end plate and the black can is bigger there.
you can get an adapter that bolts onto the end of the can with 3 allen bolts, that takes the prop.
- blue123
- Thank you received: 146
- Phil Wood
- Inactivated User
This means that the mounting bracket is at the silver end with the wires & the can would be behind the firewall.
Oddly enough, there are mounting holes on the other end on the can as well.... but that would mean the wires had to spin.
I want the motor can to be in front of the firewall to move the weight forward & let the prop stick out of the cowl.
It's easily done with a few extensions but it would just have been easier if the motor had been reversed to a rear mount.
Polyphilla wrote: .
That could be because you can loosen the grub screws at each end of the motor and then push the shaft through so that it sticks out of the other end but it takes some pushing.
- Phil Wood
- Inactivated User
I have to confess to having a complete blonde moment here & I must admit that I was tempted to delete a few posts & back track the thread so I didn't look like such a PRATT!!!!!!.Tony B. AKA Blooper wrote: the silver end with the wires on, is bolted to the outside of the firewall.
the can (which rotates) sticks out the front and takes the prop adapter.
the prop then fixes to that.
However, .... I'll take my punishment & admit that I couldn't see the wood for the trees & my mind was locked on only using the compression fit type of prop adapter that fits onto the shaft ..... not the type that bolts onto the can.
I've just received a new motor for this model anyway .... it's the same size but a bit more powerful, this one is a 3548 size (recommended) ... but it's 815 Watts, which will give me a lot more grunt.
www.hobbyking.com/hobbyking/store/uh_vie....asp?idProduct=19581
I've also received the correct mounting brackets & prop' adapters & I'll try to get started on this again as soon as I've completed the rest of the mundane tasks that plague my sorry existence.
at least you finally got your head round this simple problem, what will happen when you have to face a real problem.
- Phil Wood
- Inactivated User
Yeh, yeh, yeh, Ok Bob the Builder...... Mumble, grumble ...... I know how to face a real problem ..... I remember when you joined the forum!Tony B. AKA Blooper wrote: he he he
at least you finally got your head round this simple problem, what will happen when you have to face a real problem.![]()
I'll check the measurements tomorrow, but I've got a feeling that even with the recommended size motor, I think I may have to move the firewall back a touch, otherwise there may be a bit too much of a gap between the spinner & the cowl .... It'll all come out in the wash.
- grumpy9
Apart from all that -How the devil are you all? I had a bit of a stroke and am a bit wobbly on my feet so no flying for months.In fact ,I seem to have lost confidence in lots of fields (those with trees in in particular )Bye for now .Taken me ages to find my password etc
Grumpy Myron .
- Phil Wood
- Inactivated User
Bloody hell! .... I'm on mod' duties tonight because Garry's called in sick, & when I saw the name "Grumpy" I thought it was the other Grumpy we have registered... I didn't see the number "9" until I read the post ...... How the hell are you, you old coffin dodger?grumpy9 wrote: I'm so sorry to hear you've succombed to the lekky disease.I did for a while but I'm better now.However,I do have an easy glider I havn't flown yet .Bought it to make use of those dangerous batteries I was told I needed for the other horribly quiet machines I've built .My biggest mistake was converting a "Trixie" from a 15 to lectric .Bent prop shaft second flight and after adding extra weight cos the C ofG was apparently way out .
Grumpy Myron .
I'm been swayed to the dark side by Garry. He's one hell of a bloke & has helped me with this place so much that I've put him in charge & given him complete control .... he even cleans the bogs.
Not sure if you read all the threads Myron, so make a note of this number...... 0751 9999 234
It's the official modelchat phone number & you can get me on it at any time.
It's an O2 mobile .... but I have free minutes & can ring you back straight away. .... just in case you lose your password again.
Anyway ..... How do you like my latest venture into electric flight?
please come back and kick pol for us.
- Forum
- Forum Categories
