TN 134" LANCASTER
On Thursday i will be picking up all the bits needed to build a tony nijhius 134" Lancaster.
To upset the purists it will be electric powered.
The build will not be starting till after the hurricanes are finished ( or as near as)
Not sure how scale we are going to go on this one, but i might be tempted to cut some templates for a second one so i can go scale mad on that.
Keep your eyes peeled for a start date and updates on the build.
Tony.
i will be building some big jigs to build the bits on, so i can move the bits around safely.
8' long one piece fuselage will be fun.
looking forward to this one.
might have to make another while i'm at it.
i have cleared the space needed to build this one.
i just got to make the building board and we can get started.
as i have all the wood for this one and i am broke, the viscount will be going on hold and the lancaster will be started.
looking good for a saturday the 2nd of june start.
didn't start in the end, had the telemaster to fix.
Laid out the fuselage plan.
cut out the cnc fuselage formers.
can start to lay it up tomorrow i hope.
The plan is confusing because it shows the formers being 6mm balsa, but the cnc pack is 3mm ply.
also some of the formers are numbered wrong.
still we will get there.
cos once i have used the cnc bits i cant use them as templates.
I just have more time than most people and way less money.
Dodged the blackbird nesting on the rack
and started work.
First job was to splice 3 bits of 9.5mm square together for each stringer.
Then we could pin the first stringer down to the plan and lay up the first few formers.
Could only do 4 as the fuselage curves in in front and behind those.
Then we flipped it over and fixed the other stringer on.
Once happy i could take it off the board and pin down the top stringer and start to fit the other formers.
Where the top of the fuselage curves down, i had to glue some temporary supports in to keep the main 2 side stringers level.
and we could pull the rear of the fuselage in, in two directions.
We now have a squarish fuselage that needs to have the stringers finished off and the nose pulled in.
then we can sheet the lower sides and start on the tail.
been ill for most of it.(dizzy and hot/cold flushes, short of breath and palpitations )
so not got much done at all.
made a start on the horizontal stab.
