- Thank you received: 10722
TN 134" LANCASTER
Good luck with it anyway
until i get to the air retracts.
- Phil Wood
- Inactivated User
- Grumpy42
Press on my friend - I need the inspiration.
Alan asked about one and as it was from the manchester that the lancaster was born, i am looking into it.
i can use the plan i have for 90% of the build, just need to alter the fins and add an extra one, then reduce the wingspan and only have 2 engines.
yes if it happens it will be ic powered.
The Manchester IA, the main production version (173 built) used the Lancaster fins and tailplane so just the wing and engines are different.
Only 20 of the small tail plane 3 fin Manchester Is were built.
the 3 fin one with no mid upper turret.
measured 6 times and still had to cut twice, but the rear one is in the right place and the wings fit.
i need to move the front one by 2mm to get it in square.
the wing sits square, just about.
we are 1mm out on the level and 1mm out on the square to the fuaelage.
tomorrow i will glue the rear box in and square the wing up again and leave to dry all day.
sat will see the front box go in and then it is a case of fitting all the bracing in the fuselage.
can get back onto the wings then.
was doing ok, until it rolled off the bench.
fortunately no damage
