TN 134" LANCASTER
23 Jul 2012 13:01 #91 by Ex-Member
Replied by Ex-Member on topic Re: TN 134" LANCASTER
it can be done cos BB did it ok.
i am debating just having the tail wheel castor and not steerable.
23 Jul 2012 14:09 #92 by Garry Pollard
Replied by Garry Pollard on topic Re: TN 134" LANCASTER
Tony B. AKA Blooper wrote: it can be done cos BB did it ok.
A couple of things come to mind Tony. Firstly, with elec you dont taxi 100 yds to the pilots box (takes too much power out of the flight time), and with those huge rudders, I am sure that a castored tail wheel would work fine, but it is up to you mate
24 Jul 2012 23:10 - 24 Jul 2012 23:13 #93 by Ex-Member
spent the day after wrapping parcels, fitting the servo's in the tail.
Rudders work.:)
s5.photobucket.com/albums/y185/MUDDYJLX/...current=DSCF7348.mp4
elevators work.:)
will need a servo reverser as there are 2 servo's working the elevators.
i can now finish off the rear section and glue it to the tailplane.
started a wing panel as well. :)
Last edit: 24 Jul 2012 23:13 by Ex-Member.
27 Jul 2012 02:17 #94 by Ex-Member
done a little bit of painting this evening.
tail section is now ready for covering.
One wing getting there.
it looks big don't it.
got to make the wing boxes over the weekend.
05 Oct 2012 21:51 #95 by Ex-Member
After a loooooooooooooong break we are back on the Lancaster.
Completed the first wing box today, once it has dried i can join the wings together and make the second box, then we can fit the wings to the fuselage.
:cheer:
05 Oct 2012 23:14 #96 by The Beard
Replied by The Beard on topic Re: TN 134" LANCASTER
Didnt realise you had got so far with the Lanc Tony ,mightely impressed
01 Nov 2012 22:54 #97 by Ex-Member
Not done much to this of late. :(
I have covered the rudders and elevators over the last couple of days and today i painted the tops of the elevators.
need some matt black for the undersides and rudders.
hope to cover the whole tailplane and paint that over the weekend.
then we can cover and paint the rear half of the fuselage.
03 Nov 2012 23:20 #98 by Ex-Member
06 Nov 2012 22:01 #99 by Ex-Member
despite my bad hands today i did a little bit more painting.
just to prove it is me doing the work and not elves :P
Painted the first coat of black and done the second coat of camo.
white gaps are where the markings go.
Then some plastic cutting later we have a bit more done.
one more coat of black and we can pencil in the panel lines and finally seal with 3 coats of polyc.
i can move onto the rear of the fuselage next then.
07 Nov 2012 02:03 #100 by Ex-Member
2nd coat of black is now done.
panel lines are the next job and then we can seal it all and forget it for a while.:)
08 Nov 2012 01:03 #101 by Ex-Member
Panel lines are done.
first coat of sealer has gone on.
Started the tail end charlie's gun.
It goes in here when finished (do i need to carve a gunner)
09 Nov 2012 00:36 #102 by Ex-Member
been one of those days when you work for ages and have very little to show for it.
rear gun is ready for paint.
tail plane assembly only needs one more coat of polyc on the underside and that is done.
the fuselage has been covered from the tail to the mid upper turret and has had 2 coats of poly c.
thats been it for a longish day.
09 Nov 2012 00:48 #103 by The Beard
Well it is huge Tony so youve probably achieved a lot.
10 Nov 2012 23:35 #104 by Ex-Member
Took ages to get the tail to fit again as the covering had made it a tight fit, but it fits now.
Started slopping some paint on the tail end of the fuselage as well (another loooooong job) :P
need to make the top turret gun and paint the gun canopy, then its back to the wings i think. :cheer:
11 Nov 2012 15:47 #105 by Ex-Member
tail end charlie is ready.
Time to create page: 0.229 seconds
