TN 134" LANCASTER
08 Feb 2013 21:06 #136 by Ex-Member
Replied by Ex-Member on topic TN 134" LANCASTER
first wing box is now glued in and setting, when set i will add the 3mm spreader plates.
then once set i can re fit the wings and set and glue the front box in, this way everything will line up hopefully and make sliding the wings in and out smoother.
fingers crossed.
then hopefully on sunday i can join the wing tips to the center sections and start sheeting the tops.
09 Feb 2013 18:49 #137 by Ex-Member
front wing box is in and drying.
so sunday looks like joining wing ends to center section day.
09 Feb 2013 22:08 #138 by Ex-Member
just sorting out the extra wing box supports. (a bit belt and braces, but i want it strong)
traced all the fuselage formers ready for cutting another set, need to cut an extra F4 so i can make the nose removable for transport.
thats the next job after i have joined all the wings together.
09 Feb 2013 22:15 #139 by The Beard
Replied by The Beard on topic TN 134" LANCASTER
Coming together well,can you explain the spreader plates and what they do please Tony
09 Feb 2013 22:18 #140 by Ex-Member
they spread any loads across the frame rather than concentrating it all in one place.
should help with hard landings.
09 Feb 2013 22:55 #141 by Garry Pollard
Replied by Garry Pollard on topic TN 134" LANCASTER
You have seen my landings then Tony. Just a thank you for all your effort and dedication to this huge build, and also your attention to details.
09 Feb 2013 23:49 - 09 Feb 2013 23:50 #142 by Ex-Member
part of the bombay floor in.
wings fit ok.
can get on with the wings tomorrow maybe.
need to order some 1.5mm sheet next.
Last edit: 09 Feb 2013 23:50 by Ex-Member.
10 Feb 2013 18:39 #143 by Ex-Member
ooooooooooooooooooooops i dropped it.
10 Feb 2013 19:07 #144 by Grumpy42
Replied by Grumpy42 on topic TN 134" LANCASTER
AAAAAAAAAAAAAAAAAAAAARRRRRGH !!! My sympathies Tony - I hope the damage is not to bad. I'f it's any consolation I've been known to do the same thing. :(
10 Feb 2013 19:51 #145 by Ex-Member
Naa its ok grumpy, i have cut the nose off to make it removable for transport.
:P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P
going to have 3 wing bolts and 4 wooden dowels to hold it on.
it was either the nose or the tail and i thought the nose as it is under less stress and load when flying.
drops the fuselage length down to 62 inches.
11 Feb 2013 05:17 #146 by Grumpy42
Tony B. AKA Blooper wrote: Naa its ok grumpy, i have cut the nose off to make it removable for transport.
Mutter, mutter,mutter,mutter,mutter,mutter,mutter,mutter,mutter, :woohoo: :woohoo: :woohoo:
  • kamco kid
  • kamco kid's Avatar
11 Feb 2013 05:29 #147 by kamco kid
Replied by kamco kid on topic TN 134" LANCASTER
Aaaah, you missed an opportunity there Tony for an excuse to get a bigger car or a trailer ;)
Rich
Thanks: The Beard
11 Feb 2013 23:52 #148 by Ex-Member
right lets get back on topic shall we. :P
holes cut in thee fuselage sides to take all the wiring.
bolt holes are now sorted for the nose fitting, just gluing on each captive nut.
one at a time to ensure it all lines up.
got the locating dowels to sort as well yet.
then we can smooth the join and i could even cover and paint the nose.
13 Feb 2013 00:11 #149 by Ex-Member
all the captive nuts are on now and the locating dowels are in place.
need to smooth the join next and that's another job done.
13 Feb 2013 22:53 #150 by Ex-Member
well the nose came off again and i have added some filler to help smooth the join.
then we had a look at the nose.
Time to create page: 0.223 seconds
