TN 134" LANCASTER
11 Nov 2012 19:15 #106 by Ex-Member
Replied by Ex-Member on topic Re: TN 134" LANCASTER
a little bit more done.
12 Nov 2012 03:49 #107 by The Beard
Replied by The Beard on topic Re: TN 134" LANCASTER
Brilliant Garry must have a glint in the eye ,a rubbing of hands and an emptying of the wallet. and when it comes to the maiden flight a pinching of the buttocks. :woohoo: :woohoo: :whistle: :whistle:
12 Nov 2012 17:57 #108 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: TN 134" LANCASTER
If my experience is anything to go by, the trick is going to be finding 4 ESCs that match!
12 Nov 2012 19:42 #109 by The Beard
You may already have covered it Tony but are you going for contra rotating motors and will the props be 4 blade.How close will 4 ESC supplied by the same maker and supplier be?
12 Nov 2012 19:45 #110 by Ex-Member
contra rotating motors.
the esc's if all from the same manufacturer should be close enough.
each motor has its own battery in the cowl.
3 blade props.
air retracts
working bomb doors
12 Nov 2012 19:56 #111 by The Beard
Thanks for that Tony .Will the ESC be connected to 1 terminal on the receiver.I know with the Lanc in the club,which is IC and not flown,2 outer were on the normal throttle position and the 2 inner were on a turning knob at the top of the Tranny..They never yet got all 4 engines to run together.
12 Nov 2012 20:03 #112 by Ex-Member
all esc's will be connected to the one stick.
12 Nov 2012 20:11 #113 by The Beard
Ok thanks ,with Y leads with one wire cut I assume will you show us the proceedure when you gwt there.
30 Nov 2012 00:12 #114 by Ex-Member
The dreaded wing joiners, i have been putting this bit off for ages, so i had to bite the bullet and make a start.
Rear joint in place and pegged in temporarily to keep every thing lined up.
main join clamped in place for marking up, need to make 18mm spacers to go between the plates next.
then we can mount them in the fuselage and get the wing sections squared up.
30 Nov 2012 22:38 #115 by Ex-Member
front joiner all glued up and drying, need to run some screws through when dry and then sand to a good fit.
then i can cut the holes in the fuselage to fit them and square the wings up.
after that i can crack on with the wing and nacelles.
01 Dec 2012 21:27 #116 by Ex-Member
well it all went tits up today.
the araldite did not set on the front joiner and i have had to do it all again.:(
then while adjusting the fit of the wing sections into the box i broke a rib front section off and have had to re fix it.:(
been most of the day getting back to where i was yesterday.
lets hope the glue takes tonight and is set by morning and i can get the wing centers to join together.
02 Dec 2012 00:22 #117 by The Beard
Sorry to hear of your problems thats a frustrating day.Never heard of araldite not going off,is it a temperature thing.
02 Dec 2012 19:19 #118 by Ex-Member
well today so far has been another rubbish day.
woke up to perfect flying weather, but they have a football match on :angry: :angry: :angry:
managed to get some more done to the wing joiners.
until i stripped a thread on a captive nut that holds the wing into the box, spent ages trying to find another one.
finally got the wing boxes made and the wings joined together, now i need to take it all apart and fit them into the fuselage. :unsure: :unsure: :unsure: :unsure:
02 Dec 2012 21:27 #119 by Ex-Member
Made a tongue up to fit inside the front box.
then slid it all together and drilled the bolt holes.
next job is to fit the joiners in the fuselage (might have to wait till the weekend when i have more floor space)
04 Feb 2013 18:48 #120 by Ex-Member
Replied by Ex-Member on topic TN 134" LANCASTER
Well as i am waiting for wheels for the mustang i decided to make the ailerons for the Lancaster.
while i had the riblets in my hot hand, i used them as templates and cut another set ready for the "Manchester" build (if it happens)
hopefully if the misses goes away this weekend i can drag the table into the middle of the room and glue the wing mounts in.
needs lots of space to do this bit. :unsure:
been dreading this part of the build. :( :(
Time to create page: 0.251 seconds
