16 Sep 2013 18:22 #496 by Ex-Member
had a frustrating day today.
so much other stuff to do that i got very little done to any models.
I have cut out former F1 and epoxy'd it in place.
cut out the 2 front sides of the fuselage and wetted and curved them ready to fit.
thats it. :(
17 Sep 2013 12:49 #497 by Ex-Member
curve two bits of wood.
start clamping and gluing on.
leave to dry and hope it is all square when set.
17 Sep 2013 16:57 #498 by Ex-Member
Have a bit of a tidy up, and we have a front section made.
Tomorrow if i am allowed out, i will get the rear crutches cut and glued on, then we can spend days cutting formers and stringing the rear of the fuselage.
18 Sep 2013 17:50 #499 by Ex-Member
Rear crutches made and fitted.
i can now sit down and cut the last 3 formers and then start stringing the rear end.
only 20 years apart in design.
18 Sep 2013 22:27 #500 by The Beard
Replied by The Beard on topic Hurricane Build Tony Nijhuis design
Tony do you get RCM and E mag? the Special arrived today.It has the Tony Nijhuis P51 plan. If you would like it I can bring it when I pick up my fuselages.
18 Sep 2013 22:46 #501 by Ex-Member
i get it, mine not come yet and i dont fancy a mustang anyway. thanks for the offer though.
27 Sep 2013 17:56 #502 by Ex-Member
took a break from the se5a this afternoon and did some more to the hurricane.
cut the last 3 fuselage formers, a nice long job what with all the notches for the stringers.
then i started the first of the stringers.
i will do as many as i can with the fuselage jigged up, then by the time it has to come off the bench to have the rest done it should be rigid enough to handle and finish off.
worked ok with the last 4 i did. :P
28 Sep 2013 16:12 #503 by Ex-Member
no flying today, see beeen flying thread.
so i sat in the shed and attacked the stringers.
long slow job, but are finally done.
had to curve some balsa for the tailplane fairing first though.
next job is to cut the ribs for the tailplane and fin, then we can get them built and fitted.
28 Sep 2013 19:04 #504 by Ex-Member
well i have made the fin and is half way through building the rudder.
next job is the tailplane (or i could start another project)
29 Sep 2013 13:23 #505 by Ex-Member
fin and rudder sorted, just about.
next job is the tail plane and elevators. :P
30 Sep 2013 20:34 #506 by blue123
Replied by blue123 on topic Hurricane Build Tony Nijhuis design
Thanks a lot Tony it is looking great
  • Flytilbroke's Avatar
30 Sep 2013 23:16 #507 by Flytilbroke
Replied by Flytilbroke on topic Hurricane Build Tony Nijhuis design
Just caught up with this. Doing well you are.
08 Oct 2013 15:44 #508 by Ex-Member
tail is all constructed.
some wing ribs cut from ply.
it fits.
center section constructed.
next job is to cut more wing ribs for the outer sections.
then buy some retracts and fit them while working out the u/c legs and covers.
09 Oct 2013 16:12 #509 by Ex-Member
wing ribs.
lots of wing ribs.
and a wing under construction.
right hand wing panel almost ready to come off the board.
will attack the other panel tomorrow, then over the weekend i can glue them all together.
09 Oct 2013 17:32 #510 by Quorneng
Replied by Quorneng on topic Hurricane Build Tony Nijhuis design
That looks a rather strange wing section with its maximum thickness very far back like the laminar flow section used on the P51.
It seems strange it does not use the scale section Clark YH. Easy to build with a true flat bottom area like the Clark Y but with a slight swept up trailing edge.
Time to create page: 0.301 seconds
