02 Nov 2013 19:24 #541 by Fly-Navy
Replied by Fly-Navy on topic Hurricane Build Tony Nijhuis design
So many people have helped me in modelling over the years and "Scrooge Cantwell" gave me such a good deal on the kit Tony,if it saves you a bucket load of grief they are FOC sir !!!!!
Unless in the unlikely position you have 120 four stroke under you bench from yesteryear :silly:
02 Nov 2013 20:17 #542 by Ex-Member
ermmmmmmmmmmmmm nope on the engine, i only fly electric ( evil i know sorry)
i live 3 miles from the m25 jct 10, so i am sure something could be arranged.
thank you.
03 Nov 2013 16:25 - 03 Nov 2013 16:59 #543 by Ex-Member
I have started the ailerons this morning.
wing fairing.
the fuselage just drops inside the fairing and it helps to line up the wing bolts.
ailerons done now.
started the rad ducting.
question.
do i leave it open or blank off the ends.
Last edit: 03 Nov 2013 16:59 by .
03 Nov 2013 17:01 #544 by Eric
Replied by Eric on topic Hurricane Build Tony Nijhuis design
I may be wrong, but I understand it is best to blank off any dummy ducts, because the drag caused by the closed one is less than the open one.
03 Nov 2013 17:08 #545 by
As Eric is an accomplished typist, he beat me to it. Exactly my thoughts .
03 Nov 2013 19:22 - 03 Nov 2013 19:22 #546 by Quorneng
Replied by Quorneng on topic Hurricane Build Tony Nijhuis design
I am not sure that is always the case.
It depends on the aspect ratio of the duct. The Hurricane duct is quite deep in relation to its width and length but of course for scale looks it should not be 'empty' anyway.
I expect the difference would not be significant.
Last edit: 03 Nov 2013 19:22 by Quorneng.
04 Nov 2013 16:14 #547 by Ex-Member
Retracts going in.
and they work.
started the wheel wells.
to make life easier if you have to replace and wing or retract servo's i am fitting 2 hatches in the underside of the wing so you can get at the connectors in the wiring.
  • soloslogger
04 Nov 2013 17:02 #548 by soloslogger
Replied by soloslogger on topic Hurricane Build Tony Nijhuis design
Luvly juvly stuff mate, :)
04 Nov 2013 17:08 #549 by
The hatches are ine Tony , so long as you dont superglue the conectors together.
On the subject of leads I managed to pick a dozen 36 inch ones up at Retford for the sum of 50p each, saves on conectors
04 Nov 2013 17:12 #550 by old fart
Replied by old fart on topic Hurricane Build Tony Nijhuis design
I couldn't make them for that Garry.
04 Nov 2013 17:19 #551 by
He had over a hundred, I should have bought more :( :( neither could I Owen
Sorry Tony, off topic, but to bring it back, Super building job as usual
04 Nov 2013 17:26 #552 by Eric
You should have bought the lot, Garry, then sold them on - on here, with a markup of 5p plus p+p each!
04 Nov 2013 19:26 #553 by
Hindsight is a wonderful thing Eric :woohoo: :woohoo: :evil: :evil:
05 Nov 2013 15:18 #554 by Ex-Member
Back on topic. :cheer:
underside of the wing is now sheeted.
doors started.
used litho plate for these as it is thinner than balsa or ply and i can get it closer to the wing shape.
adding some gussets to the inside of the doors.
wiring hatches are in as well, will make life easier if you need to remove the retracts or aileron servo's.
05 Nov 2013 15:27 #555 by Quorneng
Tony
Does the Litho plate actually need the wood support? Epoxy direct to the U/C leg?
Time to create page: 0.261 seconds
