09 Oct 2013 17:49 - 09 Oct 2013 17:51 #511 by Ex-Member
hmmmmmmmmm
so it should be like this.
would it make much difference to the flying performance.
Last edit: 09 Oct 2013 17:51 by Ex-Member.
09 Oct 2013 17:57 #512 by Eric
Replied by Eric on topic Hurricane Build Tony Nijhuis design
Very draggy, and not very efficient in model sizes, I suspect, Q.
09 Oct 2013 19:13 - 09 Oct 2013 19:15 #513 by Quorneng
Replied by Quorneng on topic Hurricane Build Tony Nijhuis design
The basic Clark Y does all right for me. :P
I would be very surprised if the YH produced any more drag than the section Tony is using.
I have seen an article giving the results of some model size wing tunnel tests that showed the benefit of more modern sections (using the same chord to thickness ratio) over a Clark Y was limited about 5% at best L/D and not much more at high speed. Significant for a high performance glider but it would very little difference on a scale power plane.
The reason given was the effect of the relatively thick boundary and high viscosity (low Reynolds number) tended to swamp the true aerodynamic properties of the specific wing section.
This sort of thing could explain why the 'stepped' Kline–Fogleman airfoil sections are considered so good for models whereas NASA and others could find no benefit (but rather a penalty) in full size.
Last edit: 09 Oct 2013 19:15 by Quorneng.
11 Oct 2013 16:25 #514 by Ex-Member
hello again.
as i did nothing yesterday, i thought i better do something today.
need to sand the top down next and then sheet.
then i can work on the wing to fuselage fairing and make the wing tips.
need to order some retracts from HK over the weekend so i can get on with the underside of the wing next week.
it's starting to take shape now.
  • soloslogger
11 Oct 2013 17:16 #515 by soloslogger
Replied by soloslogger on topic Hurricane Build Tony Nijhuis design
:) :) looking great Tony,
11 Oct 2013 19:25 #516 by Ex-Member
It's looking almost as good as your SE Tony :evil: :evil:
11 Oct 2013 19:29 #517 by Ex-Member
ha ha
you would not think that there is only 20 years between them in design. :)
it will be finished one day. then i can get on with something else
12 Oct 2013 16:07 #518 by Ex-Member
well the top of the wing is now sheeted and ready for sanding.
Looks like it fits and lines up as well. phew. :P
so tomorrow i can sort out the servo trays for the fuselage and wings, then cover the underside of the wings as far as the center section.
then once the retracts turn up i can finish the wing off and move onto the nose area.
21 Oct 2013 17:41 #519 by Ex-Member
Got back onto this one today.
started planking up the nose.
can finish planking it tomorrow and then sand to shape and fit the motor mount box.
then we can move onto the retracts.
22 Oct 2013 15:53 #520 by Ex-Member
awaiting final sanding once the filler has dried.
hope to be able to cut it off tomorrow and make the motor box, then fit the screw blocks and put it back on again. :cheer:
25 Oct 2013 17:14 #521 by Ex-Member
better do an update.
nose is covered and ready to be cut off and trimmed and the mounts making.
Top of the wing is fully sheeted, i have l/e to shape and the tips to do.
underside of the wing has been sheeted to where the u/c goes, u/c mounts are in.
tail plane and fin have been glued together and are ready to fit to the fuselage.
27 Oct 2013 16:46 #522 by Ex-Member
the nose was dry so i cut it off.
made up a base for it and sanded the inside, also sealed the inside for extra strength.
The tail plane is now covered and ready to glue onto the fuselage tomorrow.
27 Oct 2013 17:14 #523 by Garry Pollard
Replied by Garry Pollard on topic Hurricane Build Tony Nijhuis design
Bet that made your eyes water, cold now gone then ?? :woohoo: :woohoo: :evil: :evil:
Sorry Tony, couldnt resist it mate
28 Oct 2013 14:24 #524 by Ex-Member
Tail has been glued and is now setting.
all square i hope. :P
if the rain stops i can take the wing outside and sand it all to shape.
28 Oct 2013 16:33 #525 by Eric
I've been reading too much text on screen - I read - sand it all to shape - as - sand it to all shapes - :oops:
Time to create page: 0.254 seconds
