Been Flying
02 Feb 2012 07:10 #151 by Phil Wood
Replied by Phil Wood on topic Been Flying
Oh bloody hell! .... I've now done a 25 hour stint & I still can't get to sleep for thinking of getting out flying again ...... it's a bloody drug!!!!! :woohoo: :woohoo: :woohoo:
02 Feb 2012 09:24 #152 by The Beard
Replied by The Beard on topic Been Flying
Very trur Poly, very true
05 Feb 2012 03:05 #153 by The Beard
Lots of snow here,could be good tomorrow with the Fun Cub
05 Feb 2012 03:18 #154 by The Beard
05 Feb 2012 03:20 #155 by Ex-Member
Replied by Ex-Member on topic Been Flying
ski's then. :P
05 Feb 2012 06:10 #156 by The Beard
The fuselage is a skiboard isnt it,With the big wheels on the Fun Cub it might well be ok it was last time.
05 Feb 2012 21:53 #157 by The Beard
Firstly I arrived at the field and connected up by the caravan and tripped putting the throttle to full, the Fun Cub wacked my leg and then the step of the caravan taking the prop off shaft and all,my stupid fault. Back home fitted another motor and back to the field.Still noone else there but the model was fairly uncontrollable .Landed in the next field made variuos adjustments and it was OK.Has a couple of flights wirh camera videoing.Camera stopped twice for some reason.On 4th take off motor went.Arrived home ,it felt stiff.Removed it and tested it all ok.looking for a spare shaft now.
05 Feb 2012 22:12 - 05 Feb 2012 22:15 #158 by Eric
Spring must be coming! It was dark at this time yesterday, and had the curtains closed and room lights on! Outside temp is +3C.
.Camera stopped twice for some reason. - COLD - these little cameras don't like the cold - (or at least the tiny lipo in them doesn't!)
Last edit: 05 Feb 2012 22:15 by Eric.
Thanks: The Beard
06 Feb 2012 03:38 #159 by The Beard
Ive been searching for a motor shaft that I knew I had.Changed it because I thought it could be that causing the vibration.Eventually found it in the shed and thought I would just show how easy they are to change.Remove any grub screws holding it in the motor,there is often more than one.I drift the broken or bent one out with the replacement shaft gently tapping or using a vice as a press/
06 Feb 2012 03:40 #160 by The Beard
Here is the broken shaft
06 Feb 2012 03:42 #161 by The Beard
If you click to make the image bigger here is where my prop landed so I had to go paddling --lovely You can just make it out
06 Feb 2012 04:32 #162 by Eric
I thought it was supposed to be attached to a motor, and the motor attached to a model! :lol:
06 Feb 2012 04:34 #163 by Ex-Member
not the way beard flies it don't.
:P :P :P
07 Feb 2012 01:12 #164 by The Beard
Well its all back in one piece ready for the next onslaught
07 Feb 2012 01:28 #165 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Been Flying
Is that a vice in the kitchen ???
Time to create page: 1.212 seconds
