3D printing Widgets
15 Jul 2022 10:14 #46 by Eric
You might also find yourself melting the servo gear-housing! :oops:
15 Jul 2022 13:23 #47 by Klipkopwildlife
Just putting ideas out there, I had in mind a surface mount hot air iron on a very low heat.
15 Jul 2022 18:23 - 15 Jul 2022 18:25 #48 by jon.in.swansea
I lightly attached the arm and horn for a test mechanical differential for the aileron. The trick for me was to limit the travel so that the arm does not go below the surface of the foam at the extents. I picked an angle that is ~35 degrees off of perpendicular as the neutral point - that seemed to be the sweet spot. However, the aileron horn is slightly shorter than the servo arm. Perhaps I should make it a bit longer to reduce the aileron movement a bit?
Up is greater than down angle. Also, the epoxy'd the new servo arm extension is used in the video.
Have a look at this 10s video. If it looks good enough I can finish the joins and get on with gluing the upper skin.... -Jon
Last edit: 15 Jul 2022 18:25 by jon.in.swansea.
15 Jul 2022 18:27 #49 by Klipkopwildlife
Works for me Jon, the amount of maximum travel you have is way more that you'll ever need.
Thanks: jon.in.swansea
15 Jul 2022 23:48 #50 by Eric
You can also reduce the throw slightly by moving the pushrod IN a hole on the servo arm. That also reduces the load on the servo.
16 Jul 2022 08:48 #51 by Klipkopwildlife
It's always a good idea to have the servo movement on 100% in the TX and adjust the total control movement (deflection) on the aircraft. The reasoning behind this is that on modern radios the servo movement is not analogue, (the stick potentiometer is analogue but is sent to an Analogue to Digital converter) but digital, 128 steps used to be the norm but some high end TX's use 256. When you adjust the total movement on the TX, reduce to 50% you now only have 64 steps for total movement which can lead to difficulties around neutral.
16 Jul 2022 12:33 #52 by Eric
Look also at dialling in some exponential on your transmitter - for ailerons and elevator. This gives you a 'softer' response around the neutral position, but still permits full deflection of the servo at full stick movement.
Some people prefer to use 'rates', which gives you a high and low (adjustable) setting - the disadvantage is, you have to remember which switch you used to select that - when you have a panic moment!
There is no switch to select with expo, it is there all the time!
17 Jul 2022 07:59 #53 by Klipkopwildlife
Because I am a 'stick banger' I use 50 to 60% Expo, it's the only way I can fly without constantly over controlling!
Thanks: Eric, jon.in.swansea
17 Jul 2022 09:48 #54 by Oily
Replied by Oily on topic 3D printing Widgets
I have an Elegoo Mars 2 Pro resin printer,so if anyone wants anything printed that needs detail(size permitting)then just ask.
I’m also building a Voron Trident printer with a 300mm x 300mm x 300mm volume so I can print ABS parts etc if anyone needs anything printed in ABS
Just sorting out the wiring at the moment
28 Jul 2022 17:48 #55 by jon.in.swansea
And finally I did get to grips with these functions. They are just shy of life changing. Smooth. And setting up differentials (albeit on top of some mechanical differential was also less fraught than I expected. Could see the differences.
I managed to get the down angle to be quite minimal while retaining the up angle. As far as I can tell the response has improved (within a limited set of flight tests).
Now I just have to replace the ESC (the T30 connector is failing) until I can re-solder the old ESC....
28 Jul 2022 17:51 #56 by jon.in.swansea
I ended up with 60% expo (actually -60% on this Futaba) to get that nice middle stick response. My earlier tests were at 25% (being cautious).
28 Jul 2022 17:56 #57 by jon.in.swansea
A rather larger beastie than my Prusa Mini. Serious printer that.
Occasionally I have wanted a bigger build volume - but the mini does take minimal space and it has forced me to be clever on the CAD designs. This ability to 'think of a thing and then make it real is the core of the fun of printers..."
Never tried ABS which would be a stretch on the Prusa with no enclosure. PLA has sufficed for my needs thus far.
Bravo that you are offering to help folk print stuff!
You know that STL files can be shared on the site. But not yet freeCAD files (unless they are zipped). -Jon
21 Apr 2024 08:47 #58 by Klipkopwildlife
Jon sent me some stl's of centre finders, very useful if you want to drill a pipe or rod.
This is the result, yes so what? I here you saying, I printed them in ABS! And they haven't pulled off the build platform.
21 Apr 2024 18:26 #59 by Eric
21 Apr 2024 21:41 #60 by Quorneng
Nice.
At that thickness you stand a chance but thicker items always bend unless the whole printer is in a hot box and the finished print allowed to cool uniformly.. .
Time to create page: 0.933 seconds
