Blackhorse Travel Air
  • The Beard
02 Jul 2012 16:00 #1 by The Beard
Blackhorse Travel Air was created by The Beard
With Galaxy not being able to supply me with an Acrowot,I wanted to give them my support and instead of going elsewhere purchase something they had in stock suitable for a 46-52 IC, yes Grumps,we live on an IC yes,yes.yes.A proper engine.I admit I do like seein my engine and being able to fit the glow and tune as easily as possible and this fits perfectly.It should be in the post today so hopefully will arrive tomorrow,but I will need to rely on my son to take delivery as Im out for the day.I have a couple of choices for engines from a new SC 52 4 stroke,an SC 52 2 stroke also new,or I could use my Tunder Tiger 46 pro from my Swift,depending what I decide on the swifts future.
  • The Beard
04 Jul 2012 20:29 #2 by The Beard
Replied by The Beard on topic Re: Blackhorse Travel Air
The kit arrived today and Ive had a quick look
04 Jul 2012 20:32 #3 by Grumpy42
Replied by Grumpy42 on topic Re: Blackhorse Travel Air
The Beard wrote: With Galaxy not being able to supply me with an Acrowot,I wanted to give them my support and instead of going elsewhere purchase something they had in stock suitable for a 46-52 IC, yes Grumps,we live on an IC yes,yes.yes.A proper engine.I admit I do like seein my engine and being able to fit the glow and tune as easily as possible and this fits perfectly.It should be in the post today so hopefully will arrive tomorrow,but I will need to rely on my son to take delivery as Im out for the day.I have a couple of choices for engines from a new SC 52 4 stroke,an SC 52 2 stroke also new,or I could use my Tunder Tiger 46 pro from my Swift,depending what I decide on the swifts future.
Good on you Stephen - keep the faith and enjoy the sound and the experience.
  • Dean M
  • Dean M's Avatar
04 Jul 2012 21:46 #4 by Dean M
Replied by Dean M on topic Re: Blackhorse Travel Air
I think these are fantastic value for money, there is a couple of these at our club they look and go great!!
I nearly choked on my latte.
  • The Beard
05 Jul 2012 02:29 #5 by The Beard
Ive been busy today so didnt get a chance to look further but a quick inspection and from what I have seen,excellant value for money and looks an excellant kit and just what I was looking for.Im busy tomorrow so may not get another look as yet,.Im fittin g a new SC 52 2 stroke into it.
  • The Beard
05 Jul 2012 18:21 - 05 Jul 2012 18:34 #6 by The Beard
Whilst waiting for someone to turn up Im spending a little time getting the parts together for the Travel Air.Just about have evrything to get started.
Last edit: 05 Jul 2012 18:34 by .
  • The Beard
07 Jul 2012 03:08 #7 by The Beard
Spent the day at hospital having tests ECG .and stuff.Couldnt get out the car park ticket was rejected.People behind me wouldnt move back so I was blocking everything up heyho.Then the GP practice might as w3e llhave been for boats.Watched the tennis,that was good.I did fit the servo ailerons,the tank,under carriage and engine,
  • The Beard
07 Jul 2012 21:56 #8 by The Beard
The wings are glued together ,Horizontal and vertical stabilisers glued inti place.The elevator servo fitedd,elevator horns fitted and pushrod connected and adjusted.R$udder servo fitted and rudder horn fitted and pushrod fitted and adjusted.Throttle servo fitted and connected up.Battery fitted into position and receiver fitted.Just the switch to fit and that is undernesth inside fuselage and is being very difficult.
  • The Beard
08 Jul 2012 03:36 #9 by The Beard
All of a sudden the Travel Air was finished all to do is adjust throws to recommended and check C of G.Nice looking model and good value for the money.
  • Dean M
  • Dean M's Avatar
08 Jul 2012 17:18 #10 by Dean M
Excellent have you plans to have a fly of it soon? B) B)
  • The Beard
09 Jul 2012 03:53 #11 by The Beard
09 Jul 2012 03:57 #12 by
Replied by on topic Re: Blackhorse Travel Air
What on earth is that ugly looking metal thing at the front:) :) :) . Apart from that, it looks good
  • The Beard
09 Jul 2012 03:58 #13 by The Beard
Here are photos of my Travel Air,very pleased with it.And just to warm Grumpys heart it has a proper engine.Which I ran today and its a lovely engine.Also ran up the Harmon Rocket engine and thats a gooden also.The Magnatilla engine is a bit erratic soit runs and revs fine but tickover is a bit hit and miss,so may fly a tank of fuel through it to see if its gunjed up.Sounds lovely on full throttle and revs up well,but tickover isnt happening then it dies.Might be the throttle closing due to the vibration but appears to work ok on the arm.
09 Jul 2012 04:09 #14 by Eric
Replied by Eric on topic Re: Blackhorse Travel Air
Check the air bleed isn't blocked with a bit of muck.
  • The Beard
09 Jul 2012 13:49 - 09 Jul 2012 13:53 #15 by The Beard
What is the air bleed please Eric ,I dont know when it was last run and when turning over it felt spongey.Starts easily and revs brilliantly .
Last edit: 09 Jul 2012 13:53 by .
Time to create page: 0.283 seconds
