Blackhorse Travel Air
  • The Beard
09 Jul 2012 13:50 #16 by The Beard
Replied by The Beard on topic Re: Blackhorse Travel Air
I hope to maiden it as soon as the weather allows.
09 Jul 2012 16:56 #17 by Eric
Replied by Eric on topic Re: Blackhorse Travel Air
The air bleed - on the carb there are two small screws, one adjusts the closed end-stop, and is usually mounted at the back of the carb, and vertically. The other is usually at the front, mounted horizontal, and across the line of the crankshaft. It blocks or unblocks a 1mm hole that alters the amount of air allowed in when the engine is at tickover, so that you can slightly richen or lean out the mix, without touching the main jets.
It ONLY affects the tickover, because as soon as you start to open the throttle, the barrel allows more mix in, bypassing the air bleed.
  • The Beard
09 Jul 2012 20:29 #18 by The Beard
Yes thanks know the one you mean,the idle screw
  • The Beard
15 Jul 2012 14:25 #19 by The Beard
The model is charged and ready,the weather looks OK,but not sure if Im well enough to go out.
15 Jul 2012 14:28 #20 by Garry Pollard
Replied by Garry Pollard on topic Re: Blackhorse Travel Air
Go for it Stephen. Be mummy s brave little soldier :) :) :)
  • The Beard
15 Jul 2012 21:48 - 15 Jul 2012 22:34 #21 by The Beard
Wasnt able to do much moving about so just popped to the field for a short time but started to feel unwell and after watching my mate fly his big Spitfire beautifully came home.\\\\\\\\\\\\\\\\\\\\\soon though.
Last edit: 15 Jul 2012 22:34 by Garry Pollard.
  • The Beard
22 Jul 2012 02:06 #22 by The Beard
Great day today maidened the Travel Air and its superb.Havent found myself taking off and landing a model so easily so quickly thoroughly enjoyable model and day.
  • The Beard
23 Jul 2012 22:24 #23 by The Beard
Good day flying spent time tuning engine ran our of fueland glided foe over 400 metres before landing.Prepared for next flight, brought it forward onto the restrainer and the undercarriage fell off.No damage just not very strong.
24 Jul 2012 14:46 #24 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Blackhorse Travel Air
Glad to see you're back flying again S, you've been having a rough time just lately.
  • Dean M
  • Dean M's Avatar
24 Jul 2012 16:31 #25 by Dean M
Replied by Dean M on topic Re: Blackhorse Travel Air
Sounds like a good model you have there. Hope it is a quick and easy fix!
I nearly choked on my latte.
  • The Beard
29 Jul 2012 01:36 #26 by The Beard
Yes Dean its fixed,went to the field to fly and the fix had blocked the holes for the wing dowels.I meant to drill them out before I left for the field but only realised I hadnt when I went to pop the wing on.In fact I will go and drill them out now cheers.Yes Tony my operation wound is beginning to not be sore but my knees are hurtin g a lot lately.I do as much as I an during a day until the pain gets to much and hav e to sit down.
  • The Beard
30 Jul 2012 02:53 #27 by The Beard
Two problems today the engine starts and sounds fine,but when I power up to take off it stops.tried tuning but so far unsuccessful.the other one is the reasr steersble wheel.Its to weak and I cannot get it straight,need to change it.Now I always keep such things but cant find one anywhere more searching tomorrow.
30 Jul 2012 02:59 #28 by Eric
You have an air leak or a blockage in a fuel line, by the sound of it.
Unplug all the pipes, and have a good blow down them, then put a spare piece of fuel tube on the carb nipple, take the needle valve right out, open the throttle wide, and have a good blow down that, in case there's a bit of muck in the jet.
If that doesn't work, check that the carb screws are tight, where they hold it onto the crank-case, and check the case backplate screws are tight.
30 Jul 2012 12:28 #29 by Klipkopwildlife
Of course, since you have two identical motors you could swop them over! But I'm guessing that's a lot of work!
  • The Beard
30 Jul 2012 21:00 #30 by The Beard
Good idea Tony then the problem would be on the Harmon Rocket,Its a strange one as its fine once in the air
Time to create page: 0.300 seconds
