TN 134" LANCASTER
14 Feb 2013 21:51 #151 by Ex-Member
Replied by Ex-Member on topic TN 134" LANCASTER
the nose section is getting covered.
the wing sections are getting joined together.
they is BIG.
that's a 4ft building board.
when dry and when my half a ton of 1.6 balsa turns up, i can sheet the top of the wings and start on the engine nacels.
15 Feb 2013 01:19 #152 by Ex-Member
one done. one to go.
15 Feb 2013 03:44 #153 by Ex-Member
well here is 130 inches of wing, need to tips to take it to the full 134inches.
only just fits in my conservatory/build room.
15 Feb 2013 22:53 #154 by Ex-Member
wing tips fitted, will need shaping once i have sheeted the wings.
front section getting a coat of paint.
just trying a pair of nacelles for size.
and so we plod on.
17 Feb 2013 00:13 #155 by Ex-Member
bit of black.
sheeting the tops of the wings.
they are uncut 4ft long sheets of balsa. :blink:
once i have the tops all sheeted, we can turn them over and fit the nacelles.
17 Feb 2013 23:15 #156 by Ex-Member
well not much to report today, been flying.
nose section has some more paint on it.
the wings have some more wood glued to the top surface.
thats all folks. [badass]
17 Feb 2013 23:20 #157 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic TN 134" LANCASTER
Those wings are like sheeting doors i found, looking good Tony
17 Feb 2013 23:22 #158 by Ex-Member
yeah, tell me about it.
you sit down, 2 hours later you stand up, strech the aching back and find you are only half way.
18 Feb 2013 20:57 - 18 Feb 2013 20:59 #159 by Ex-Member
been out there since 10 am and still don't look like i have done anything.
got some more sheet on the tops of the wings.
then i cut out all the nacelle parts and cut the battery holes in 8 formers.
glued the inner ones together ready for fitting.
got the first pair of nacelles fitted and drying.
Oh i marked round all the inner nacelle parts onto ply, ready to cut out for the Manchester (if it happens)
Last edit: 18 Feb 2013 20:59 by Ex-Member.
18 Feb 2013 22:32 #160 by Ex-Member
took some of the bits outside as i needed a boost as this one is taking forever to build.
got the next set of nacelles gluing on now and is working on the underside sheeting of one wing.
just doing the bits that do not cover any wiring runs.
18 Feb 2013 23:53 #161 by Garry Pollard
Replied by Garry Pollard on topic TN 134" LANCASTER
Lets be serious about this Tony, what the hell have I let you in for when I suggested this.
I suppose I should say sorry, but the only words I can think of are "Thank You Mate
19 Feb 2013 04:26 #162 by Ex-Member
we will plod on slowly.
one day it will be finished and i can do something else. :cheer:
19 Feb 2013 05:20 #163 by a4kskyhawk
Replied by a4kskyhawk on topic TN 134" LANCASTER
wow that looks very nice and big tony great work done.
19 Feb 2013 18:54 #164 by Ex-Member
Well after another couple of hours, we have the top of one wing sheeted and part of the underside sheeted as well.
19 Feb 2013 21:48 #165 by Ex-Member
After yet another couple of hours i have made the aileron servo mounts for both wings.
fitted the supports in one wing and nearly finished the sheeting (as far as i can go) on the wing.
this is killing me. :)
could have built a sports plane in the time i have spent on these wings so far.
:P :P :P :P
Time to create page: 0.569 seconds
